dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Replacing Z71 hub front bearing, power steering pump?
What is the difficulty rating for this as a DIY? I've seen the videos for this and it looks real easy to do.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Mon Aug 01, 2011 6:03 pm |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
 Re: Replacing Z71 hub front bearing, power steering pump?
Wheel bearing hub assembly is very simple. Have not done power steering pump yet.
_________________ 18x54 WC custom 36PD EFI
Mon Aug 01, 2011 6:30 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Hub is easy. Power steering pump is not, a lot of sht to come off, and a lot of fun trying to get the threads started on the lines once you remove them, they are buried. I gotta replace mine soon, just did the pressure side hose, it sucked.
_________________ Put yer face in the myrtles.
Mon Aug 01, 2011 6:57 pm |
jack3
Joined: Fri Aug 07, 2009 10:01 am Posts: 410 Location: n/e Alabama
pay someone to do it (mechanic ?) spend valuable time doing important things !
Mon Aug 01, 2011 7:54 pm |
dguidry
Mon Aug 01, 2011 8:12 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
Change the hub bearing is east. Take the brake off. 36mm socket for the cv shaft. Then 3 bolts on the back side of the hub.
The power steering pump should be easy also
_________________ I gave up mud motors
Mon Aug 01, 2011 10:21 pm |
coastal
Joined: Wed Jan 14, 2009 8:29 am Posts: 1890 Location: South TX
Just changed both of mine. Left side went out at 95k so I changed both and put new shocks and brakes.Very easy I will find you a link. DO NOT BUY THE CHEAP SHIAT!!! Buy Timken or NAPA's BEST!!! Link!!!! http://reviews.ebay.com/Chevy-Silverado ... 0002536494
_________________ I will keep my gun's,freedom and money.You can keep your change!
Tue Aug 02, 2011 3:18 pm |
MaXXis85
36 MM socket for the CV nut, and 15mm is the size for the 3 bolts holding the hub to the knuckle. You will also have to pull the brake caliper off aswell. About 1 hour per side.
PS pump isnt that big of a deal either. Undo the lines, and the bolts that hold the pump on. THe hardest part is threading the fittings back onto the steering gearbox. If you need more room, remove the 2 lower steering box bolts and Loosen the upper and rotate the box as you need. I am not certain but I think you will need a PS pulley puller to remove and re install the pulley onto the new pump. To remove the Serpentine belt put a 3/8" ratchet/ breaker bar in the square hole in the tensioner to releve tension and remove belt. Follow the diagram on the sticker that is on the plastic cowling above the radiator.
Tue Aug 02, 2011 3:26 pm |
dguidry
Thanks to everyone who took the time to respond to my post.
Tue Aug 02, 2011 5:18 pm |
