It is currently Thu Jul 17, 2025 10:46 am
Reply to topic  [ 9 posts ]
 Replacing Z71 hub front bearing, power steering pump?
Post Replacing Z71 hub front bearing, power steering pump?
What is the difficulty rating for this as a DIY? I've seen the videos for this and it looks real easy to do.
Mon Aug 01, 2011 6:03 pm
Post Re: Replacing Z71 hub front bearing, power steering pump?
Wheel bearing hub assembly is very simple. Have not done power steering pump yet.
18x54 WC custom
36PD EFI
Mon Aug 01, 2011 6:30 pm
Hub is easy. Power steering pump is not, a lot of sht to come off, and a lot of fun trying to get the threads started on the lines once you remove them, they are buried. I gotta replace mine soon, just did the pressure side hose, it sucked.
Put yer face in the myrtles.
Mon Aug 01, 2011 6:57 pm
pay someone to do it (mechanic ?) spend valuable time doing important things !
Mon Aug 01, 2011 7:54 pm
Mon Aug 01, 2011 8:12 pm
Change the hub bearing is east. Take the brake off. 36mm socket for the cv shaft. Then 3 bolts on the back side of the hub.
The power steering pump should be easy also
I gave up mud motors
Mon Aug 01, 2011 10:21 pm
Just changed both of mine. Left side went out at 95k so I changed both and put new shocks and brakes.Very easy I will find you a link. DO NOT BUY THE CHEAP SHIAT!!! Buy Timken or NAPA's BEST!!!
Link!!!!
http://reviews.ebay.com/Chevy-Silverado ... 0002536494
Tue Aug 02, 2011 3:18 pm
36 MM socket for the CV nut, and 15mm is the size for the 3 bolts holding the hub to the knuckle. You will also have to pull the brake caliper off aswell. About 1 hour per side.
PS pump isnt that big of a deal either. Undo the lines, and the bolts that hold the pump on. THe hardest part is threading the fittings back onto the steering gearbox. If you need more room, remove the 2 lower steering box bolts and Loosen the upper and rotate the box as you need. I am not certain but I think you will need a PS pulley puller to remove and re install the pulley onto the new pump. To remove the Serpentine belt put a 3/8" ratchet/ breaker bar in the square hole in the tensioner to releve tension and remove belt. Follow the diagram on the sticker that is on the plastic cowling above the radiator.
Tue Aug 02, 2011 3:26 pm
Thanks to everyone who took the time to respond to my post.
Tue Aug 02, 2011 5:18 pm
Users browsing this forum: No registered users and 75 guests
