MudBuddy77
Joined: Mon Oct 03, 2011 5:56 pm Posts: 298 Location: Caddo lake
 Pvt 308 cam - lifters?
I've heard several say to change the lifters out when installing a new cam. Of course I bought mine from an individual but he didn't send the lifters to me. Just got done reading that most cams come with new Briggs lifters. What should I do? Change out the lifters or use my old ones?
| Mon Jul 25, 2016 12:49 pm |
cb5331
 Re: Pvt 308 cam - lifters?
Pretty much no cams for these motors other than BPS or PVT are sold with new lifters. You can order new ones or resurface the one's you have.
| Mon Jul 25, 2016 12:54 pm |
MudBuddy77
Thanks. I reckon I'll just order new.
| Mon Jul 25, 2016 1:00 pm |
Will C
Ive watchin your build . What are you goin to run for heads?
| Mon Jul 25, 2016 1:45 pm |
MudBuddy77
Havin a local Do it. Decking .50 port n polish. Manley valves.
| Mon Jul 25, 2016 3:01 pm |
brickgw
I hope you told the local guy .050 and not .50 lol
| Mon Jul 25, 2016 3:10 pm |
ibfishinb
Buy lifters. Delta sent me lifters with my cam.
| Mon Jul 25, 2016 4:00 pm |
flint87
| Mon Jul 25, 2016 4:17 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
Don't waste your money
_________________ I gave up mud motors
| Mon Jul 25, 2016 7:38 pm |
MudBuddy77
Yea I guess I shoulda said .050, and I'm suppose to be getting different springs with the pink shims I believe, and why do you say don't waste my money? Probably be getting the same exact (look fine to me but what do I know) lifters I just took out? Btw anybody got any part numbers for the crankcase gasket and o rings? I found very little info on part #s while searching. I've got a 13 gtr. Thanks
| Mon Jul 25, 2016 11:11 pm |
Will C
Looking foward to a reveiw. For partnumbers google twofeathers small engine/vanguart parts. Its a shortcut. There are many others too
| Mon Jul 25, 2016 11:20 pm |
Russ
Partstree.com for part numbers. Just need the model number.
| Tue Jul 26, 2016 4:26 am |
MaXXis85
New or resurfaced "Spinners" should be used. If you resurface make sure to retain the slight taper they have ground into them to keep it spinning so they do not dig into the camshaft lobe. New lifters are $20-25 last I recall ordering a set.
| Tue Jul 26, 2016 5:11 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Tue Jul 26, 2016 5:19 am |
MudBuddy77
Yea I'm not searching for parts/gaskets etc. based on the lower unit... Haha. I'm looking for Briggs part #'s. Thanks guys I'll check out those sites.
| Tue Jul 26, 2016 6:31 am |
flint87
| Tue Jul 26, 2016 6:56 am |
