It is currently Mon Apr 13, 2026 2:29 am
Reply to topic  [ 16 posts ]
 Pvt 308 cam - lifters?
Post Pvt 308 cam - lifters?
I've heard several say to change the lifters out when installing a new cam. Of course I bought mine from an individual but he didn't send the lifters to me. Just got done reading that most cams come with new Briggs lifters. What should I do? Change out the lifters or use my old ones?
Mon Jul 25, 2016 12:49 pm
Post Re: Pvt 308 cam - lifters?
Pretty much no cams for these motors other than BPS or PVT are sold with new lifters. You can order new ones or resurface the one's you have.
Mon Jul 25, 2016 12:54 pm
Thanks. I reckon I'll just order new.
Mon Jul 25, 2016 1:00 pm
Ive watchin your build . What are you goin to run for heads?
Mon Jul 25, 2016 1:45 pm
Havin a local Do it. Decking .50 port n polish. Manley valves.
Mon Jul 25, 2016 3:01 pm
I hope you told the local guy .050 and not .50 lol
Mon Jul 25, 2016 3:10 pm
Buy lifters. Delta sent me lifters with my cam.
Mon Jul 25, 2016 4:00 pm
Mon Jul 25, 2016 4:17 pm
Don't waste your money
I gave up mud motors
Mon Jul 25, 2016 7:38 pm
Yea I guess I shoulda said .050, and I'm suppose to be getting different springs with the pink shims I believe, and why do you say don't waste my money? Probably be getting the same exact (look fine to me but what do I know) lifters I just took out? Btw anybody got any part numbers for the crankcase gasket and o rings? I found very little info on part #s while searching. I've got a 13 gtr. Thanks
Mon Jul 25, 2016 11:11 pm
Looking foward to a reveiw. For partnumbers google twofeathers small engine/vanguart parts. Its a shortcut. There are many others too
Mon Jul 25, 2016 11:20 pm
Partstree.com for part numbers. Just need the model number.
Tue Jul 26, 2016 4:26 am
New or resurfaced "Spinners" should be used. If you resurface make sure to retain the slight taper they have ground into them to keep it spinning so they do not dig into the camshaft lobe. New lifters are $20-25 last I recall ordering a set.
Tue Jul 26, 2016 5:11 am
Tue Jul 26, 2016 5:19 am
Yea I'm not searching for parts/gaskets etc. based on the lower unit... Haha. I'm looking for Briggs part #'s. Thanks guys I'll check out those sites.
Tue Jul 26, 2016 6:31 am
Tue Jul 26, 2016 6:56 am
