It is currently Sun Jun 22, 2025 9:51 am
Reply to topic  [ 32 posts ]
 Pvt 493f cam problems
Post Pvt 493f cam problems
In the process of a stage 1 put the cam in the other night every thing went fine torqued the case bolts 90in. Pounds in the proper sequence. Sat down to drink a beer maybe 5 to 10 min after and here a ping sound from the motor. Really had me worried but retired for the night cause the beer was tasting to good. This morning I noticed that I couldn't turn the motor over by hand so decided to tear it down again and this is what I found .
1754 gt pushed by stock 35 gtr
Sat Apr 05, 2014 2:06 pm
Post Re: Pvt 493f cam problems
Looks like improper tooth alighnment with the governor gear, but I could be wrong.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sat Apr 05, 2014 2:12 pm
^^ this,
You can see the governor gear marks on the cam. Man that sucks! Also the case bolt torque specs should be 200 in. the oil pump to case cover is 90.
Sat Apr 05, 2014 2:28 pm
Not saying y'all are wrong but the reason the marks are there is the first time I slid it on it was off so I adjusted it then slid it back on . I just looked at the gov gear there isn't even a mark on it . Wouldn't it have been hard to bolt up if it wasn't aligned right? Don't remember having any trouble . Thanks for the clarification on the torque specs .
Sat Apr 05, 2014 2:33 pm
Also since I mistakenly torqued them to only 90in. Pounds . Would that have been enough pressure to crack the cam like that ?
Sat Apr 05, 2014 2:37 pm
Did you have to bump the cover around to get it to line up or go on? It doesn't take much pressure to crack that cast.
Sat Apr 05, 2014 2:55 pm
From what I remember it went on fairly easy . But I'm leaning towards what y'all are saying . I don't see any thing else that could have happened . Unless it was already cracked and I didn't see it.
Sat Apr 05, 2014 3:05 pm
Do they recommmend that hole as the timming mark in the cam?
Sat Apr 05, 2014 3:07 pm
Yeah they did had a tag on it when I received it saying to use the big hole .
Sat Apr 05, 2014 3:14 pm
The only thing I can think of is something didn't line up right when putting the cover on. But then again u wouldn't of thought the cover would have went all the way on without forcing it.
Sat Apr 05, 2014 3:21 pm
Pvt doesnt make the 493f cam. Hope this helps. :lol:
Sat Apr 05, 2014 3:44 pm
The only thing on the # 1 cylinder side the cam gear that could have caused a binding issue would be the governor gear. if you look at the cams breaking point and split the difference again it puts at 7:30 -8 o-clock the center at the govern gear.
Sat Apr 05, 2014 3:46 pm
Sat Apr 05, 2014 3:49 pm
Sat Apr 05, 2014 3:59 pm
Maybe try doing it sober when you put it back together? :D
Sat Apr 05, 2014 4:12 pm
Sat Apr 05, 2014 5:26 pm
so EVT is making cams again? but my buddys cam from PVT had a tag saying use the big timing mark?
Sat Apr 05, 2014 7:36 pm
Sat Apr 05, 2014 7:41 pm
Sat Apr 05, 2014 7:45 pm
Actually now that I look it is an pvt
Sat Apr 05, 2014 7:47 pm
send it back
- Mark Twain
Sat Apr 05, 2014 7:49 pm
Sat Apr 05, 2014 8:06 pm
Sat Apr 05, 2014 8:07 pm
Der... just saw the above posts.
Sat Apr 05, 2014 8:08 pm
My bad fellas thought I was getting a 493 I'd edit it if I could but can't edit the title
Sat Apr 05, 2014 8:15 pm
You can change the title if you edit the first post, but it ain't no big deal. It doesn't help you solve your problem either way. :lol:
Sat Apr 05, 2014 8:18 pm
Some of Al's blanks as of recently were missed marked, this is the reason for the other timing mark and the tag explaining what timing mark to use.
Sat Apr 05, 2014 8:58 pm
We'll good news there sending me a new cam in the mail [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT]
Mon Apr 07, 2014 7:09 pm
Wow that's good of them. Lay off the booze this time :lol:
Mon Apr 07, 2014 7:25 pm
Haha I'll try ..
Mon Apr 07, 2014 7:41 pm
round 2... hahaha
Mon Apr 07, 2014 7:45 pm
also remember 200in lbs I bought motor they didn't torque to corret and lost 3 bolts and it leaked before I lost bolts now doesn't leak a drop
Kleibert custom 18/50 push by a 35 gdsd with a lil pixie dust
Tue Apr 08, 2014 10:17 pm
Users browsing this forum: No registered users and 176 guests
