It is currently Tue Apr 07, 2026 8:22 am
Reply to topic  [ 14 posts ]
 what are some simple mods for stock engine?
Post what are some simple mods for stock engine?
I am looking for another 100 rpms while running my longtail, 23 vanguard engine all stock
I put in a weekend of research on the governor, from what I can tell I'm not gona get any out of it as its a simple butterfly valve an it's all the way open as it is when throttle is applied?
I'm looking to get more air flow maybe k&n filter..
Will look into drilling out my main jet 2 bit sizes..
Don't want a new carb.
Not yet ready for head work.
Anything wrong with my ideas so far?
Going to Disney World is like Going To the DMV, Instead of Walking out Once Finished Jumping Back In Line At the DMV…
Sun Jul 24, 2016 6:35 pm
Post Re: what are some simple mods for stock engine?
Wouldn't fuck with drilling out jets, seen that go wrong many times. Doubtful that a k&n filter is gona do anything for you without any other mods.
If you ain't gona spend any money on it you ain't gona feel any difference.
Good news is the carb setup for the 23 is cheaper. Having the heads decked locally with a valve job is pretty cheap too.
Check the classifieds for a used exhaust. You could do it all under a grand maybe less.
Sun Jul 24, 2016 6:58 pm
Good advice on drilling out jets, that's what I'm trying to feel out
Sun Jul 24, 2016 7:04 pm
Gut the muffler
I gave up mud motors
Sun Jul 24, 2016 7:26 pm
Sun Jul 24, 2016 8:55 pm
One of the small things the 23 likes is a timing key. 7* is common but i like 4* . 7* can sometimes make it a bit hard to start. Advance keys are a cheap way to add cyl pressure.
Sun Jul 24, 2016 8:59 pm
Advance timing? I always herd of retarding the timing (never done it) but retarding creates longer strokes an more power?
Correct me if I'm wrong.
I would gut the muffler but I like the quiet motors for hunting.
Mon Jul 25, 2016 5:19 am
It sounds like you need to get a tach, and research the governor a little more. The governor is a mechanical part inside the block. As RPMs increase, it moves a lever that closes the butterfly in the carb. Typically that's about 3600RPMs. You can bend and tweak the governor mechanisms to change the range the governor functions. You can turn it up to 4000-4200 out of water, and in the water its not going to have enough ass to reach those RPMS - but you'll still turn more than you're turning now.
Mon Jul 25, 2016 6:09 am
Look up Deadbird8's thread on carb mods.
He does a lot to the carb, doing away with the hard 90* angles and stuff.
Its got a lot of pictures.
Ill see if I can dig it up tonight.
Sat Jul 30, 2016 5:22 pm
Stock carb tuning question
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
See if this works, dead bird shared some info in this one
Sun Jul 31, 2016 8:38 am
Mon Aug 01, 2016 4:22 am
I have a tach and now I have achieved 3950- 4000 rpms now I'm holding 22mph and touching 23(normal conditions)... satisfied setup feeling strong
Mon Aug 01, 2016 7:18 pm
I appreciate the feed back on deadbirds info
Mon Aug 01, 2016 7:19 pm
