It is currently Mon Apr 06, 2026 11:51 am
Reply to topic  [ 6 posts ]
 Rpms
Post Rpms
Just bought a rig guys. It has a 2010 36 prodrive on it. The tach on it went out and I ordered one this morning. Me and one other guy topped out at 22 mph in it. It's on a 17x48 x series. I'm really thinking I'm not getting the rpms I should be. Also, in gear when I idle, I have to feather the throttle to keep it from dying. It's just running at really low rpms. I don't want to mess with anything until the tach comes in, but after that how can I adjust the rpms? I'm running stock everything. I know this is probably blatantly obvious but this is my first sd. Thanks for any help
Sat Mar 25, 2017 11:08 am
Post Re: Rpms
How's the prop?
Sat Mar 25, 2017 11:46 am
Post Re: Rpms
Could be a dirty carb or need a simple carb adjustment but good chance it needs a valve job or head gaskets as worse case scenario. This pic is your idle rpm screw. Shit pic i know. You might need to find someone to give it a checkup since you just got it
Sat Mar 25, 2017 11:47 am
Post Re: Rpms
I will add that i recently saw 2 different bone stock prodrives that ran 23 wide open on an 1850 with a little weight. Yours isnt too bad but your shit idle has me thinking motor isnt healthy
Sat Mar 25, 2017 12:01 pm
Post Re: Rpms
Once I get the tach out on I'll try to figure it out. If not I'll take it to prodrive. The guy had just gotten a 300 hour done on it from prodrive and it's at 360. New carb, etc. I checked compression when I bought it and I was running 130 psi out of both cyclinders.
Sat Mar 25, 2017 12:50 pm
Post Re: Rpms
Go find the post about bending the tab on the governor spring linkage, that solves the idle woes most of the time...
PRODRIVE 1860 CC
"Let the good times roll"
Sun Apr 02, 2017 1:46 pm
