It is currently Wed Apr 01, 2026 5:36 pm
[ 6 posts ] |
estadalis
 Rpms
Just bought a rig guys. It has a 2010 36 prodrive on it. The tach on it went out and I ordered one this morning. Me and one other guy topped out at 22 mph in it. It's on a 17x48 x series. I'm really thinking I'm not getting the rpms I should be. Also, in gear when I idle, I have to feather the throttle to keep it from dying. It's just running at really low rpms. I don't want to mess with anything until the tach comes in, but after that how can I adjust the rpms? I'm running stock everything. I know this is probably blatantly obvious but this is my first sd. Thanks for any help
| Sat Mar 25, 2017 11:08 am |
flint87
 Re: Rpms
How's the prop?
| Sat Mar 25, 2017 11:46 am |
Will C
 Re: Rpms
Could be a dirty carb or need a simple carb adjustment but good chance it needs a valve job or head gaskets as worse case scenario. This pic is your idle rpm screw. Shit pic i know. You might need to find someone to give it a checkup since you just got it
| Sat Mar 25, 2017 11:47 am |
Will C
 Re: Rpms
I will add that i recently saw 2 different bone stock prodrives that ran 23 wide open on an 1850 with a little weight. Yours isnt too bad but your shit idle has me thinking motor isnt healthy
| Sat Mar 25, 2017 12:01 pm |
estadalis
 Re: Rpms
Once I get the tach out on I'll try to figure it out. If not I'll take it to prodrive. The guy had just gotten a 300 hour done on it from prodrive and it's at 360. New carb, etc. I checked compression when I bought it and I was running 130 psi out of both cyclinders.
| Sat Mar 25, 2017 12:50 pm |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
 Re: Rpms
Go find the post about bending the tab on the governor spring linkage, that solves the idle woes most of the time...
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
| Sun Apr 02, 2017 1:46 pm |
[ 6 posts ] |
