It is currently Fri Jun 27, 2025 10:44 pm
Reply to topic  [ 12 posts ]
 Pulling Flywheel - Help
Post Pulling Flywheel - Help
I need to pull the flywheel off my 23 vanguard. I've got all the shrouding off and am at the flywheel nut. What's the best way to get that thing off and back on when I re-assemble? Obviously the flywheel wants to spin when I turn the nut, so what's the best way to keep the flywheel from spinning so that I can get the nut off? Thanks for the help fellas.
1644 Go-Devil
2008 23 GDSD
Wed Apr 21, 2010 8:40 pm
Post Re: Pulling Flywheel - Help
Use a large screwdriver (flatblade) to put a bind on the flywheel. Install the screwdriver between the case ,or studs against the middle of the flywheel teeth. I hope you can understand what Im meaning. Kinda hard to explain without pictures.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Wed Apr 21, 2010 9:25 pm
I used an impact to bust the nut loose just a small jolt. Then just sprayed a lol wd 40 and tapped it with a rubber hammer and it slid off. Why you pullin the flywheel already.
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Wed Apr 21, 2010 9:33 pm
I used a length of angle iron with holes drilled in it to attach to the face of the flywheel. It levers against the studs for the shroud to steady it while removing/installing.
Thu Apr 22, 2010 5:02 am
go pick up a harmonic balancer puller from any of the "big chain" automotive stores.
Thu Apr 22, 2010 9:14 am
By the time I saw coondik's message, I had already gone to Oreillys and rented a harmonic balancer puller. It worked like a charm and if I take it back within 48 hours I get my money back :D
1644 Go-Devil
2008 23 GDSD
Thu Apr 22, 2010 10:50 am
I use a BF'ing Hammer with puller ingraved on it. It works well.
BUCK OFAMA
Sat Apr 24, 2010 12:41 pm
Watch Silk use two screw drivers and an airhammer. Comes off easy! :shock:
Sat Apr 24, 2010 4:35 pm
Nah.... drake1.... Its kick the feet up, then watch Silk... Maybe grab a beer cause by the time you get up to get it he will be asking for his.
Sat Apr 24, 2010 5:00 pm
Where's the motor?
Sat Apr 24, 2010 5:27 pm
where's what motor?
1644 Go-Devil
2008 23 GDSD
Sat Apr 24, 2010 9:17 pm
he was asking about my motor.... we are in the process of getting ready to build my Generac
Sun Apr 25, 2010 9:38 am
Users browsing this forum: Google [Bot] and 153 guests
