It is currently Sat Jun 28, 2025 10:03 am
Reply to topic  [ 14 posts ]
 27 PD blown, trying to remove.
Post 27 PD blown, trying to remove.
getting ready to take 27 off and pop 32 on. got 4 motor mount bolts off but cannot budge engine off of shaft. am i missing somthing here? Don't want to ^%$# up the clutch or lower unit trying to get the old motor off. Is (just pry till it gives) the solution? thanks.
Sat Jul 10, 2010 2:03 pm
Post Re: 27 PD blown, trying to remove.
We took one apart the other day and there was an extra 2 nuts and bolts. Smaller than the main 4 and towards the front of the boat. Going through the same plate as the 4 though. If that makes sense. Other than that, yeah just wiggle it back and fourth and lift it. Shouldn't take too much to pop it off. We lifted off an 04 motor a few months back and didn't have any issues. I think you need a new tiller assembly too, in order to swap for the 32. Wouldn't swear to it, but I'm pretty sure.
Sat Jul 10, 2010 2:08 pm
18x48 Charles Leonard / 36PD
Sat Jul 10, 2010 4:02 pm
Make sure you are removing the correct 4 bolts!!The long ones that goes from plate to plate!!Not the 4 on the engine!!Top Plate stays on until you remove the clutch!!Hope this helps!!
Sat Jul 10, 2010 4:21 pm
hey just a question? where did u get the 32hp is it a kohler or briggs an how much for it? thanks!
Sat Jul 10, 2010 8:13 pm
Brandnewengines.com 32 hp briggs. around 1800.00. I have one of the original 27hp PD's so from what i understand i should be able to use exsisting tiller handle.
Sun Jul 11, 2010 5:41 am
Sun Jul 11, 2010 5:44 am
is there a bolt or screw threaded into the end of the shaft? where i must remove clutch to see?
Sun Jul 11, 2010 5:47 am
Sun Jul 11, 2010 2:31 pm
Then remove large bolt in center of clutch in the crankshaft!Make 2 wedges and remove clutch evenly and you should be good!!Neverseize everything when you put it back together!!Good Luck!!
Sun Jul 11, 2010 4:27 pm
thanks for the advice. I will let you know how it goes. little bit at a time after work only gets you so far per day.. looks like i might as well spring for a new clutch as well since im in it that far. thanks again.
Tue Jul 13, 2010 7:33 am
hey did u ever put on the new motor, how much trouble was it, i have a bad 27 an thinking about doing the same thing replacing it with a 32 thanks :D
Mon Jul 19, 2010 5:05 pm
got motor off. first day off of work, working on clutch now. seems to be good so far. runnin late on the time frame for getting this thing done. work sucks. i need to start playing the lotto more often. ill let you know how it goes. as far as the motor im using, i think its a good deal. the upgrades will make it (carb kit and s/s exaust) will make it about a 35 i think. just blowin smoke probably, we'll see how the b?#$% runs.
Tue Jul 27, 2010 3:52 pm
hey thanks! i removed the 27 on mine, removed clutch but decided to go with a new one don't want any troubles anytime soon and am installing the new motor hopefully be done soon and will let u no how it works! :D
Wed Jul 28, 2010 7:39 pm
Users browsing this forum: Google [Bot] and 154 guests
