It is currently Mon Jun 30, 2025 2:00 am
Reply to topic  [ 25 posts ]
 RPM"S on Gator tail 35
Post RPM"S on Gator tail 35
How many rpms should a gator tail 35 be turning in the water?
Tue Aug 24, 2010 7:56 pm
Post Re: RPM"S on Gator tail 35
Depends on the boat size and load in the boat. Anywhere between 3700-4200.
Tue Aug 24, 2010 8:29 pm
Boat is a 18x54 gator trax and had about a 500 lb load. Was only getting about 3250 rpms and that seemed a little low to me. Is that low?
Tue Aug 24, 2010 8:41 pm
im runnin a 1756 and with one other guy in ideal conditions i only get about 3700
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Tue Aug 24, 2010 8:53 pm
Tue Aug 24, 2010 8:55 pm
I was just test driving the boat today so nothing i can really do with it yet. I just wanted to make sure I could get a little more out of that engine if I buy it.
Tue Aug 24, 2010 9:07 pm
That should be turning in the high 3000's low 4000s if it will not get there, I would personally leave it alone- you don't want to buy a problem.
Wed Aug 25, 2010 5:11 am
Wed Aug 25, 2010 5:42 am
x3
Wed Aug 25, 2010 7:21 am
how much of the propr should be in the water when running? I may have had it trimmed wrong (this is only my second time driving one). Think I will go back and check the out of water rpm's these should be around 4200? Is that right? If the out of water is ok then it is probably operator error on the in the water rpm's.
Wed Aug 25, 2010 8:00 am
My stock motor would get to 3900 ish empty and 3750 with a load. 1748 bateau
Wed Aug 25, 2010 8:01 am
Wed Aug 25, 2010 8:03 am
Well i know i didnt have it trimmed up that much so thats part of the rpm problem.Anybody know what it should turn out of water?
Wed Aug 25, 2010 8:25 am
Neutral RPMs should be 4250 RPMS when the governere will start bouncing.
Wed Aug 25, 2010 9:17 am
Thu Aug 26, 2010 10:02 pm
My 1860 gt boat - 3800-4000 depending on load. Wot
Sat Aug 28, 2010 6:07 pm
I have a 1754 gtr extreme and out of water rpms r 4200, in perfect conditions in water itturns up 3600-3660 max. Does this seem low? I would like it to turn 3800-3900. With men and a friend I run bout 25, what can I do?
Tue Aug 31, 2010 1:09 am
In your case I dont think turning the governer up will free up much more rpms. Might seem dumb, but are you trimming the motor up enough to let the engine spin faster? My stocker would get 3800-3850 stock in deep and ran about 27-28ish.
Tue Aug 31, 2010 7:52 am
That's maxing out the trim n the middle hole
Tue Aug 31, 2010 8:20 am
Tue Aug 31, 2010 8:23 am
Yea it seems like it's half out, ima try the top
Tue Aug 31, 2010 9:14 am
mr draggin,my rpms were close to the same as yers.one thing you can do is stage 1.mine turns 4050 in the water with a new prop and i only run the tips out da water.my boat is not a mm hull,so it prob.wont ever perform like one but to me,the stage 1 made a big diff.,my boats always loaded.to me it dont seem to push more with the prop half way out the water,it just makes a prettier rooster tail,more rpms,noise and harder to hold on to.jmo.
Wed Sep 01, 2010 7:12 am
Got the motor up to 3850 running with just me which got me going 28 mph. The boat wont go over 4000 out of the water so i guess i need to adjust the governor up to 4200. Should the idle be 1100 out of water?
Wed Sep 01, 2010 11:27 am
idle in neutral usually should be 1150-1250 depending how you want it. When the prop is submerged in gear idle will be about 950-ish
Wed Sep 01, 2010 11:58 am
Wed Sep 01, 2010 5:46 pm
Users browsing this forum: Google [Bot] and 109 guests
cron
