It is currently Wed Jul 02, 2025 3:56 pm
Reply to topic  [ 17 posts ]
 Go Devil trouble
Post Go Devil trouble
Hey guys, take a look at this pic and let me know what is my best option in trying to fix this. I was on my way home from building blinds and oil starting leaking. When I got to the launch this was the cause of the leak. If you look at the bottom right of the motor you can see the inch long crack at the bottom of the motor. WHat do you guys think is my best option?
Thu Oct 14, 2010 3:32 pm
Post Re: Go Devil trouble
That pic is REALLY zoomed in. I was having a hard time with it. The only crack I could see looked like it was below the engine in the frame, but that could just be a scratch. I'm guessing its in the block below the case gasket? If so, you can get a new oil sump. Seen one for a kohler on ebay for 75 bucks the other day. Don't know what a briggs would run ya.
Thu Oct 14, 2010 3:45 pm
you can get that welded and it will fix it right up. let me ask this does your handle bolt through the frame and up through those 2 motor mounts or does your handle bolt underneath the motor in the center with 4 bolts?. because if its the one that bolt through the motor mounts you need to get rid of that handle and get the style that bolts underneath. i had the exact problem with my 27hp godevil LT awhile back and i broke mine in the same spot pushing down on the handle and it ended up breaking a piece off the motor that the handle bolted to. i called and talked to coco about it and that is what he suggested to me get it welded and get the other handle because they have had alot of issues with it busting the case.
Thu Oct 14, 2010 3:53 pm
i talk to a local welder here in mississippi and he refused to weld it for me. How much was the new handle?
Thu Oct 14, 2010 3:57 pm
ithink it was 69 or 79 dollars i cant remember which. so im guessing u have the one that bolts through the motor?
Thu Oct 14, 2010 4:03 pm
Thu Oct 14, 2010 4:20 pm
yes it is 2006 16hp go devil bad design
Thu Oct 14, 2010 4:34 pm
anyone know of a good welder who could do this for me in south misssissippi or south eathern louisiana?
Thu Oct 14, 2010 5:18 pm
i know you know this but remind the guy whoever is doing it to CLEAN IT VERY GOOD. we had a hell of a time getting it welded with no little leaks. after we welded it we used a air compressor and set it low and blew some air into the oil drain hole and put some soapy water where the weld was and everytime we was getting bubbles until we finally got it. so i would advise u to be there when he welds it and do some testing to make sure its not leaking because the welders around here dont wanna go back and redo it for free. i actually took mine to a shop first and that was the problem i ran into, the weld looked good so i took it home put it all together put some oil in it and whaddya know it was leaking and he wasnt doing it agian.
Thu Oct 14, 2010 5:37 pm
the guy i brought it too would do it, he makes aluminum boats too,
Thu Oct 14, 2010 5:40 pm
Alright guys, talk to godevil today they are going to fix me right up and I am getting that new handle also thanks for all the help!
Fri Oct 15, 2010 3:29 pm
good deal, post up some pics of the weld when u get it finished
Fri Oct 15, 2010 5:20 pm
did u ever do anything with this?
Fri Oct 22, 2010 8:01 pm
Just got call from go devil, my original estimate was $180.00, they call me today and its a total of $356.00, that is without the new handle, I pick it up tommorow afternoon i will post some pics...
Thu Oct 28, 2010 11:03 am
Here is the Fix, ran like a champ!
Mon Nov 01, 2010 8:55 pm
shouldnt have anymore problems with that with the new style handle.
Tue Nov 02, 2010 12:00 pm
nope thanks for the help !
Tue Nov 02, 2010 3:06 pm
Users browsing this forum: Google [Bot] and 124 guests
