It is currently Thu Jul 03, 2025 3:32 am
Reply to topic  [ 29 posts ]
 Surface Drives: 23 hp Go-Devil vs. 23 hp Mud Buddy HD Mini
Post Surface Drives: 23 hp Go-Devil vs. 23 hp Mud Buddy HD Mini
I don't know anything about these engines or about mud motors in general. I have a 16 ft hull and wanting to know which of these 2 engines is faster and can take the most pounding. Where I hunt is shallow mud flats with stumps everywhere and which one out of these 2 can cut it? Thanks
Wed Feb 09, 2011 4:26 pm
Post Re: Surface Drives: 23 hp Go-Devil vs. 23 hp Mud Buddy HD Mi
search.php
The search feature may answer some of your questions.
There are more questions than that to gettin a good rig.
How fast do you want to go?
What type of load do you normally carry?
Is your hull a Mod-v
If it is a thin hull you may want to look into a thicker hull built for mudmotors, a mudmotor and stumps will beat a boat up quick.
Wed Feb 09, 2011 4:31 pm
:lol: NONE, Go get you a 23 GT................But if your mine is set on those two than I would pick the GDSD.
Wed Feb 09, 2011 4:37 pm
Instead of considering the mini, look into the LA Special. It's an all around better frame than the mini, unless you are more concerned with the weight of the motor than the performance. That said, if weight is your primary concern is weight, the 23 Mini is the lightest 23 available.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Feb 09, 2011 4:55 pm
The hull is an old monark flat bottom (POS), but don't have the money to buy a new hull. It is usually 2 guys and 2 dozen decoys, sometimes 3 guys and a dog. I would like to get up to speeds around max. 25 mph. Is there not a problem hitting stumps and logs with these mud motors? I was told to get a tall transom mud motor as well and wondering can the weight of the motor handle such a light boat? Thanks
Wed Feb 09, 2011 6:10 pm
With that boat, 23 mini, unless ya go smaller.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Feb 09, 2011 6:17 pm
What kind of speed am I lookin at with 2 guys in it and a 23 mini?
Wed Feb 09, 2011 6:20 pm
Probably 23-25 max, I'm guessin
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Feb 09, 2011 6:23 pm
Will the transom on the boat be alright with that motor?
Wed Feb 09, 2011 6:29 pm
If it were me, I'd beef it up as much as possible. Even that lil motor is gonna beat the help outta the transom. Where are ya located?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Feb 09, 2011 6:44 pm
They will both hold up to stumps. MB has a clutch.
Wed Feb 09, 2011 6:56 pm
I'm in TN. How exactly do you beef up the Transom? Thanks
Wed Feb 09, 2011 9:01 pm
Find u a person that weld's aluminum and tell him u need to beef up the transome and he should know what to do!!
Wed Feb 09, 2011 9:59 pm
I'd be very suprised if you get mid 20's with two guys and a huntin load with a 23 on a monarch hull.
Does the bottom have dents by the braces especially near the transom?
That can kill performance with mudmotor (mine is sufferin).
It will work if thats all you have... I saw you mentioned a tall transom motor, that all depends on if your boat is tall transom (around 20")
I would recomend you get it built up to tall and have some more braces on the transom to handle the beating a mudmotor will put on a hull.
Wed Feb 09, 2011 10:11 pm
Is a 23 hp just not enough to get up to 20 mph? or does the problem lie on the hull? There are no dents anywhere around the transom from what I can see after scraping off all this damn snow. It's got the ridges running down the bottom of the hull, will that effect performance?
Thu Feb 10, 2011 11:41 am
No u need to be lookin for waves on the botom not on the transome is what they are talkin about!!!
Thu Feb 10, 2011 3:49 pm
What are the waves on the bottom? my bad
Thu Feb 10, 2011 4:15 pm
The 23 GDSD is the only way to go! Tough as nails in the stumps and no clutch to burn up. I have a 23 GDSD on a G3 boat sitting in my shop. It is a nice rig for sure.
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu Feb 10, 2011 4:47 pm
the bottom being bent in between the braces when u look under the boat!!!
Thu Feb 10, 2011 5:42 pm
Ok. Thanks for all your help guys. I think I'm gonna go with the 23 hp Mud Buddy.
Thu Feb 10, 2011 7:05 pm
that would be my choice man!!!
Thu Feb 10, 2011 7:31 pm
Give me a shout if ya lookin for a new one. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Feb 10, 2011 9:00 pm
Owner
Fri Feb 11, 2011 9:33 am
Don't knock it till ya try it, Jesse
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Feb 11, 2011 6:49 pm
Ya, I'm definitely looking for a new one. What is the preferred height of the transom on the boat that would fit best for a 23 hp mud buddy mini? Thanks (I'm retarded) haha
Fri Feb 11, 2011 10:54 pm
While tall (20") transoms are better, there's nothing wrong with short (16") transoms. Just get the motor that fits your boat. If ya set on a tall, but boat's a short, ya can get it built up to 20".
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Feb 11, 2011 11:08 pm
Sat Feb 12, 2011 8:29 am
Owner
Sat Feb 12, 2011 9:06 am
Owner
Sat Feb 12, 2011 9:08 am
Users browsing this forum: Google [Bot] and 102 guests
