It is currently Wed Jul 02, 2025 10:02 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 GTR23 drive disassembly help!
Post GTR23 drive disassembly help!
As many of you know, I picked up a new performance cam from GT last week. Today did some preliminary installation planing. I remove the clutch cover to discover the disassembly of the drive belt, clutch and reverse is not intuitive at all. If someone would be so kind as to explain the process I'd appreciate it.
Sun Feb 13, 2011 5:10 pm
Post Re: GTR23 drive disassembly help!
Prolly not many know how to?
Sun Feb 13, 2011 9:15 pm
The following statement kinda goes along with Keith's cam install post. If ya don't know how to get to the 1st step in the directions, ya probably shouldn't be trying to do the mods by yourself. In other words, if ya can't even get the belt drive off, do ya honestly believe ya can install a cam on ya own? :roll:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Feb 13, 2011 9:23 pm
Got to learn somehow camo... It's not that hard once you get into it, just take your time and make sure you put everything back the way it came off.
Sun Feb 13, 2011 9:27 pm
The best way to learn how to fix somethin is to fuk it up first.
Your not rebuildin an auto transmission, its a briggs and stratton on a rubber band.
Sun Feb 13, 2011 9:31 pm
The crankcase/cam part looks easy. Not sure how to disasemble the clutch/reverse from the crankshaft. There is a bolt at the very end. Do I start with that. I'll post pics tomorrow for reference.
Sun Feb 13, 2011 9:46 pm
use a impact the bolt will come right out. slide the brake rotor off and theres 6 allen bolts in there, pull the shaft out its about 4 inches long and keyed. then your going to have to pry the pully and clutch off in one piece. correct me if wrong.
Sun Feb 13, 2011 9:58 pm
also, pull the belt off while pulling the clutch off and put it on in the installation process to avoid taking the lower drive system out.
Sun Feb 13, 2011 10:00 pm
Thanks so much. I have a puller I used to pull off the fly wheel.
So I unscew the bolt then the reverse disc and its attachments will slide off. What will remain is the belt gear and clutch and I pull that off the crankshaft with the puller. It seems I should first release tension on the belt by loosening the engine from the frame first. Yes or no?
Sun Feb 13, 2011 10:15 pm
yes. and that flywheel puller wont work use to pry bars and take your time.
Sun Feb 13, 2011 10:17 pm
Prybars and patience do not go together well with me. Should be interesting.
Sun Feb 13, 2011 10:22 pm
they will come to instinctively after 200 dollar clutch
Sun Feb 13, 2011 10:27 pm
Thank you Garret.
Sun Feb 13, 2011 10:45 pm
no prob. it wasnt long ago i was on here asking the same thing.
Sun Feb 13, 2011 10:46 pm
Mon Feb 14, 2011 7:33 am
Mon Feb 14, 2011 7:42 am
Here's photo of drive assemble for my GTR23
Walk me through dis-assembly, please. Thanks for your help. I really appreciate it.
Mon Feb 14, 2011 1:50 pm
bump: I added photo
Mon Feb 14, 2011 2:45 pm
Lefty....Loosey
Righty...Tighty
Mon Feb 14, 2011 3:58 pm
I think I've got enough info to give this a try. But if anyone wants to volunteer more that would be good, too.
Mon Feb 14, 2011 4:36 pm
you need a license to practice law? they should make people have one to buy tools :roll:
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Mon Feb 14, 2011 6:21 pm
:lol:
Mon Feb 14, 2011 6:49 pm
Bring it to GatorTail before you F it all up! Hoyt will fix you up.......
Mon Feb 14, 2011 6:50 pm
Mon Feb 14, 2011 6:59 pm
18x54 WC custom
36PD EFI
Mon Feb 14, 2011 7:03 pm
Some of y'all just don't get it. Life is the journey. I build my own boats so what do you expect of me. I spent many years educating myself, making sacrifices early on so I could reap benefits today. So while some of you forkers were getting drunk and not doing your homework my arse was in study mode. So I can do stuff like build my own boats, produce and record artists, and educate my children in the finest schools, and most of all be happy, without worry. Just sayin...
Mon Feb 14, 2011 7:23 pm
18x48 Charles Leonard / 36PD
Mon Feb 14, 2011 7:28 pm
I hope you are better at all the rest of the things you speak of cause i seen your boat!! :lol:
17x48 extreme stage 2 GTR
Mon Feb 14, 2011 7:31 pm
Mon Feb 14, 2011 7:33 pm
Mon Feb 14, 2011 7:43 pm
Mon Feb 14, 2011 8:01 pm
d guidry not trying to be a smart ars but if you cant do the task with the drections we gave you, you should bring it to someone.
Mon Feb 14, 2011 8:47 pm
The fact that some of us forkers were too busy getting drunk and not studying doesn't make you any smarter. And you're asking us dumbforks for help. That's a statement not a question so you need not reply.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Feb 14, 2011 8:48 pm
Mon Feb 14, 2011 8:57 pm
Mon Feb 14, 2011 8:59 pm
Mon Feb 14, 2011 9:02 pm
short fictional story. If someone is on here all hours of the day, and while he/she was at there desk with multiple monitors, It seems as high and mighty as they think they are, they are either on a break all the time, clocked off the case, or billing some poor drunk hundreds of dollars an hour while they spew there BS about how they worked sooo much harder than the rest of us poor drunk stupid saps. In my opinon, reached from posts, and the time they make these posts, it would be a reasonable assumption that the above could be happening.
This is just a fictional account of events not to resemble any real person living or dead just a story not to be confused with reality :idea:
Tue Feb 15, 2011 7:24 am
Since I was one of those who got drunk and didn't study, I can tell you who we did it.
First you take your trailer and hook it to your vehicle and then take a chain and wrap it
around the drive assembly and use your other vehicle to pull it off. A 25 foot chain with a lot
of slack and just hit the gas on the vehicle that has the chain to it should do the job.
Tue Feb 15, 2011 12:55 pm
Tue Feb 15, 2011 1:54 pm
Users browsing this forum: No registered users and 71 guests
