It is currently Sat Jul 05, 2025 2:53 pm
Reply to topic  [ 12 posts ]
 Crankcase Leak
Post Crankcase Leak
I have been really busy trapping right now and cant afford to stop and tear the motor down to fix this right now. I have a small oil leak on the crankcase. Is their any type of silicon or gasket sealer I can put on the outside to get me buy for a couple weeks.
Wed Mar 02, 2011 1:59 pm
Post Re: Crankcase Leak
If it is just a small leak I would not worry about it.
Just fix it when you have time.
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Wed Mar 02, 2011 2:07 pm
I just want somthing to even slow it down a little. I hate having a oil residue in the water where I'am trapping. It is a slow leak but I can see right where its coming from.
Wed Mar 02, 2011 2:33 pm
Is there a heavy duty gasket people are using to replace the one we have, or just going with another one from Briggs?
Wed Mar 02, 2011 2:41 pm
try a two part epoxy
Belzona would work &hit sticks to anything dont even have to clean it first
http://www.belzona.com/
Aucoin 20X48 36pd
Wed Mar 02, 2011 3:25 pm
Wed Mar 02, 2011 3:33 pm
I got the leak to almost nothing but still want to replace the gasket, I ended up just snugging up 2 of the case bolts where it was leaking and it seemed to almost stop it. I see it a little yet so I will order a new gasket int he next couple weeks. Thanks
Thu Mar 03, 2011 6:56 am
Keep a close eye on it. My buddy did the same thing, only to find out his block was cracked & gettin worse. Hopefully that's not the case here tho.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Mar 03, 2011 8:55 am
I looked at it pretty close and it is up on the right side of the crankcase I can see a piece of the gasket and i think it is torn. Hopefully thats all it is. I will know more when I get done trapping and tear it apart. Do you guys recommend that EVT gasket or just a stock one. .
Thu Mar 03, 2011 11:35 am
They usually leak by the serial number plate. Pretty typical.
Thu Mar 03, 2011 11:40 am
Thu Mar 03, 2011 12:05 pm
Do your cam while you have it open and thank me later.
Thu Mar 03, 2011 9:23 pm
Users browsing this forum: No registered users and 127 guests
