It is currently Fri Jul 04, 2025 4:59 am
Reply to topic  [ 37 posts ]
 PD lift handle prototype
Post PD lift handle prototype
I been playin around with a design for a cool PD lift handle on the mill, this is the first one I came up with. The overall height will be pretty much the same as the stock one, but the handle will be horizontal. The pic shows the face of the plate that faces out. Still toying with ideas of what to make the handle itself out of. This one is made of 3/16", but the real ones will be made prolly 3/8 thick. Give me yalls input, I want to make the design that everyone likes. I can change anything about the shape except the overall length.
Thanks,Rod
Tue Mar 08, 2011 2:02 pm
Post Re: PD lift handle prototype
cant figger out how to make the damn pic smaller so you can click and enlarge it
Tue Mar 08, 2011 2:03 pm
Well.......................I guess I wont be making any more since I cant compete with that. That looks great man. Amazing what can be done with a cnc.
Tue Mar 08, 2011 2:05 pm
it all depends on what they wanna spend, these will not be cheap.
Tue Mar 08, 2011 2:07 pm
Cool,
I'm not a big fan of the top end of it, it looks like the end of an adjustable wrench.
Tue Mar 08, 2011 2:09 pm
there will be a socket head bolt that goes through there
Tue Mar 08, 2011 2:10 pm
How will it attach to te engine??
Tue Mar 08, 2011 2:37 pm
itll have two pieces of angle that will bolt in place of the factory plate, then the two machined plates will bolt to the angle with bolts through the sides. The handle will be a solid rod with threaded ends and bolts will go through the top hole in each plate. some sort of rubber, maybe shrink tubing will cover the solid rod.
Tue Mar 08, 2011 2:42 pm
I think you should tig the sides to a plate that mounts to the engine.
Looks good --- Possibly something that is the highest point of the engine and curve it to the back some so any branches wont be hitting the carb or air cleaner
Tue Mar 08, 2011 3:32 pm
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Mar 08, 2011 9:46 pm
Looks cool as shit to me! I like it. You wanna trade? lol
Really fine job Rod! When can I come over and play? :lol:
Tue Mar 08, 2011 11:31 pm
i appreciate that preston! man youre welcome to come by anytime!
Tue Mar 08, 2011 11:44 pm
What's the word on these?
Tue Jun 21, 2011 1:05 pm
hey whats the bolt sticking out for on the lower unit?
Tue Jun 21, 2011 7:05 pm
ha, ****** rig tension knob.
Tue Jun 21, 2011 7:09 pm
do what?
Tue Jun 21, 2011 7:12 pm
n i g ger rig tension knob. The reverse system works like a ratchet. If your using a ratchet and the bolt you are trying to undo is loose and there is no tension, then your ratchet wont work. likewise with the reverse system on the PD, the tension knob puts some pressure on the lower unit so that the ratchet reverse can function, if there is no pressure, then it wont work, just like trying to use a ratchet on a loose bolt.
Tue Jun 21, 2011 7:16 pm
i see. thanks for the info
Tue Jun 21, 2011 7:26 pm
Preston it just looks like you could lose a finger if you grabbed that bar in the wrong place
Tue Jun 21, 2011 8:20 pm
17x48 extreme stage 2 GTR
Tue Jun 21, 2011 8:21 pm
Ehhh, fingers are over rated! lol
Tue Jun 21, 2011 10:06 pm
1748 prodrive 36 fpr w/ some bolt ons...
Tue Jun 21, 2011 10:19 pm
Wed Jun 22, 2011 12:45 pm
Wed Jun 22, 2011 12:46 pm
Nah I'm good, Best I can do is say it was one of those Dee-dee-deeee moments. Plus I'm sure you have way better stories than mine! lol
Wed Jun 22, 2011 12:50 pm
How much for the handle?
Wed Jun 22, 2011 1:02 pm
They will Prolly ne about 200
Sun Jun 26, 2011 7:47 pm
GET TO WORK!!!
Sun Jun 26, 2011 8:18 pm
18x48 Charles Leonard / 36PD
Sun Jun 26, 2011 8:28 pm
That looks very simple and functional... Very nice.
Sun Jun 26, 2011 8:30 pm
Dats a BB special.
Sun Jun 26, 2011 8:33 pm
Looks good Poker! First time I've seen it mounted.
Mon Jun 27, 2011 2:36 am
Be cool if you could make one look like a pistole grip or the grip of a knife or brass knuckles.
A lanyard and a few empty shells dont make you a duck hunter- Duck Commander
Mon Jun 27, 2011 7:02 pm
Or just a plain handle that a self-respecting white man could use.
Mon Jun 27, 2011 8:06 pm
Looks kinda 70's to me. Just an opinion-
Put yer face in the myrtles.
Mon Jun 27, 2011 9:20 pm
Mon Jun 27, 2011 9:43 pm
Tue Jun 28, 2011 6:09 pm
Users browsing this forum: No registered users and 101 guests
