It is currently Sat Jul 05, 2025 5:51 am
Reply to topic  [ 9 posts ]
 Mb trim
Post Mb trim
My trim keeps cutting out. Like it will work then stop then start working again. It seems like a bad electrical connection but can't find anything. Is there like a circuit breaker or something on it?
17x50hd gator trax 45mag mb
Wed Mar 16, 2011 6:41 pm
Post Re: Mb trim
Make sure everything is real tight at the battery and not corroded.
Wed Mar 16, 2011 7:08 pm
Post Re: Mb trim
Alright I'll check that thanks
Wed Mar 16, 2011 7:11 pm
Post Re: Mb trim
Like Owen said, check everything out & make sure ya gettin a good contact. There is a self resetting circuit breaker on it also. There are 2 of them mounted on the back of the starter. They're covered with a yellow plastic cap on each one. One's for the trim, the other for the clutch. If ya order em from MB, ya lookin @ about $20 each, but ya can get em from any auto parts store for about $5 (just make sure to get a 15 amp, not a 40 amp).
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Mar 16, 2011 8:55 pm
Post Re: Mb trim
IF its a defective part, it should be cover under warranty i would think.. if your still in warranty
Gave up hunting ducks and started underwater basket weaving!
Wed Mar 16, 2011 8:59 pm
Post Re: Mb trim
Ya it's still under warranty. The battery terminals are tight and not corroded. It never stops working completely just cuts in and out.
Fri Mar 18, 2011 5:47 pm
Post Re: Mb trim
Mine did that this past winter. It's the upper breaker (with the yellow cap, as was posted earlier) that controls the trim. It's an auto-resetting breaker so when they start to go, they'll do exactly what you're talking about. Napa sells the part for about $8, might be able to find it cheaper at autozone but the one near me didn't have the 15 amp. If this doesn't fix the prob, shoot me a pm
Maybe one day I'll have one again
Fri Mar 18, 2011 6:41 pm
Post Re: Mb trim
Alright thanks I'll just go ahead and change it out and see what happens. My motor only has 15 hours on it,
Fri Mar 18, 2011 7:29 pm
Post Re: Mb trim
Sat Mar 19, 2011 4:57 am
Users browsing this forum: Google [Bot] and 126 guests
