It is currently Fri Jul 04, 2025 5:12 am
Reply to topic  [ 29 posts ]
 how much to deck heads
Post how much to deck heads
I know this has been tossed around some on here after searching the forums for info. I never ran across some solid numbers. Does anyone know what compression = how much decking.
Say you wanted to run no more than 9.5 :1...how much would you deck the heads?
I may be wrong but on pump gas you should not go over 10:1 correct?
Thu Apr 07, 2011 10:20 am
Post Re: how much to deck heads
Stay conservative
Thu Apr 07, 2011 8:10 pm
I understand your point and agree. Just trying to figure out how much compression some of these .060 decked heads are running vs lets say .025
Thu Apr 07, 2011 9:04 pm
Id say nothing more than .030
Thu Apr 07, 2011 9:12 pm
What if you took a 10:1 motor and made it pull in 1.5 cups? would 1.5 x 200= BOOM?
Thu Apr 07, 2011 9:51 pm
just put flat top pistons in, and don't deck
1754 Gatortail with 35 GTR
1748 prodrive pushed by a genny (SOLD)
I shoot black mallards does that make me guilty of a hate crime?
Thu Apr 07, 2011 10:02 pm
Thu Apr 07, 2011 10:15 pm
Thu Apr 07, 2011 10:19 pm
Fri Apr 08, 2011 5:46 am
Deck your heads in the .020-.030 range.
Fri Apr 08, 2011 6:19 am
I love seeing all you Briggs fe's giving advice on head decking....
Fri Apr 08, 2011 7:28 am
Well do tell then Mr Briggs
Fri Apr 08, 2011 7:55 am
Fri Apr 08, 2011 7:57 am
Fri Apr 08, 2011 4:16 pm
OOPS === guess thats what I get for not reading it all the way -- LOL
Fri Apr 08, 2011 5:36 pm
Stock Briggs is 8.5 to 1.
Fri Apr 08, 2011 7:18 pm
im no mechanic but it sounds like if you leave your heads stock you would have more power, just put a cam exhaust and carb and be done with it...correct?
Fri Apr 08, 2011 7:24 pm
Both will make more power. Do both together and make a lot more power.
Fri Apr 08, 2011 7:50 pm
The point of my post was simply to see if anyone knew what kind of compression was being run from say .060 decked heads and say .025 decked heads since I have read those numbers allot on here. Stock compression according to vangaurds web site says 8.2 to 1. ( http://www.vanguardengines.com/vanguard ... al%20Shaft
Fri Apr 08, 2011 8:33 pm
Sat Apr 09, 2011 7:25 am
So what would be best to deck my heads wit, a hammer and chissel or a hacksaw ???
Sat Apr 09, 2011 8:21 am
Sat Apr 09, 2011 8:22 am
Sat Apr 09, 2011 8:27 am
Make sure you have plenty of silicone , it holds up better than stock gaskets and hugs the contours of the grind if not done evenly.
Sat Apr 09, 2011 8:29 am
Sat Apr 09, 2011 10:26 am
Figures.....
The first thing that comes to Brad's mind is allways food.
Sat Apr 09, 2011 10:31 am
This thread is about ENGINE compression not ASS compression Brads!
Sat Apr 09, 2011 10:40 am
Compression is compression -- lOL
Sat Apr 09, 2011 10:41 am
Sat Apr 09, 2011 10:44 am
Users browsing this forum: No registered users and 106 guests
