It is currently Thu Jul 03, 2025 5:18 pm
Reply to topic  [ 19 posts ]
 Oil Leak
Post Oil Leak
What's your opinion on this one? I have a oil leak coming from my block, but it's a very small one. Not sure if I have a pin hole in the gasket or something like that but I noticed it about 2trips ago and I keep monitoring the oil level to make sure I'm ok. I haven't even noticed a change on the dipstick yet. Is it something I should be worried about even though I'm not leaking alot of oil?
Boats and hoes!
2007 GatorTail 35 on 18' x 46" GatorTail hull
Fri Apr 29, 2011 6:24 am
MMT Moderator
Post Re: Oil Leak
That's a case gasket leak & they almost ALL for the most part do this... I think its like arond ~ $100 to replace if that sometimes dealers will warranty just have to call & ask.
GTB 1860 w/ 2019 GTR40XD-HO
Fri Apr 29, 2011 6:41 am
Post Re: Oil Leak
Only worry if you have to keep tightening the bolts in the cover. Have seen a few motors weld the cams to the cover because of loss of clearance between the two.
Fri Apr 29, 2011 7:09 am
Post Re: Oil Leak
Just brought my boat to calens engine service in Franklin for the same problem.He explained to me why they leak right there, they all do sooner or later. My valves was leaking also,80% on one side and 40% on the other. He been having it for two weeks, i cant wait to get it back and go see if it makes a difference.
Sun May 01, 2011 4:00 pm
Post Re: Oil Leak
so what did he say about why they all leak there?
Sun May 01, 2011 4:05 pm
Post Re: Oil Leak
Get one of the foam wrapped metal gaskets from EVT and be done with it ;)
Post Re: Oil Leak
They have two holes that feed the oil filter that is pressurized,and the bolt holes are to far away.
Sun May 01, 2011 4:21 pm
Post Oil Leak
Mine just started that today .
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Sun May 01, 2011 4:27 pm
Post Re: Oil Leak
How much did your stage one cost you, my warranty is almost done?
Sun May 01, 2011 4:45 pm
Post Oil Leak
About 1800
Sun May 01, 2011 4:46 pm
Post Oil Leak
Let me know what you so with that oil leak.
Sun May 01, 2011 4:47 pm
Post Re: Oil Leak
If its still under warranty have briggs pay for the repair.
Sun May 01, 2011 7:04 pm
Post Re: Oil Leak
Mine started doing it at 30 hours.
"We Are Products Of Our Decisions"
Sun May 01, 2011 7:16 pm
Post Re: Oil Leak
Briggs is payn for my repairs to the gasket and the valves,thank god for warranty i just have 103hrs on the motor.
Sun May 01, 2011 7:19 pm
Post Re: Oil Leak
Finally got my boat back from the machnics shop,gained 300 rpm's and 4mph. Im so ready to go bowfishing now.
Wed May 04, 2011 8:31 pm
Post Re: Oil Leak
cool, what did he do to fix your valves? Lap them in?
Wed May 04, 2011 8:39 pm
Post Re: Oil Leak
I got the same issue with my GTR right now. Im worried about having a briggs lawnmower place do the repairs just bc I don't know how hard it will be to get the clutch off, since they arent familiar with that part. anyone know if this should be an issue? also, put IM heads, with rockers, and pushrods, wondering if my warranty might be void anyway bc of this.
Thu May 05, 2011 7:52 am
Post Re: Oil Leak
Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Thu May 05, 2011 12:06 pm
Post Re: Oil Leak
All i know is one was leaking 80% and the other 40%. It had 40lb difference in compression,its fixed now.
Thu May 05, 2011 8:29 pm
Users browsing this forum: No registered users and 146 guests
cron
