It is currently Fri Jul 04, 2025 12:37 pm
Reply to topic  [ 18 posts ]
 23 hp mud buddy longtail help!!!!
Post 23 hp mud buddy longtail help!!!!
the problem i am haveing is it runs good out of the water but runs like crap in the water has anybody had this problem if so please help!!! it is lugging bad under a load
Tue Jun 14, 2011 6:25 pm
Post Re: 23 hp mud buddy longtail help!!!!
Could be a number of things. Intake leak, trash in fuel system, air leak in fuel system, bad fuel pump, clogged jet, bad oil pressure sensor, bad diodes (can't remember if the 23 has diodes or not). Process of elimination starts now.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jun 14, 2011 7:37 pm
Sounds like one cylinder is dead. Now figure out why.
Tue Jun 14, 2011 7:54 pm
i have cleaned the carb and ajusted the valves but still it dose the samething so wat do i need to check first?
Tue Jun 14, 2011 8:07 pm
Check for intake leaks by spraying all of the joints with carb or brake parts cleaner while the motor's running. Check the oil pressure sensor by simply unplugging it while running the motor under a load. Check the diodes the same way, but they are harder to access & when they're unplugged you can't shut off the motor (not even with the kill switch).
Just because you cleaned the carb, don't rule out a fuel issue. Could be as simple as a bad connection @ the tank, or a bad primer bulb.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jun 14, 2011 8:16 pm
ok i am gonna go try that now and how will if i know if the diodes are bad wat will it do
Tue Jun 14, 2011 8:19 pm
IF the diodes are bad, the motor will run right when they are disconnected.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jun 14, 2011 8:24 pm
ok and when i was messing with it i was lookin at the fuel filter and there was bubbles and it was back fireing is there anyway to put a electric fuel pump in it or wat should i do
Tue Jun 14, 2011 8:44 pm
and is 9x7 prop to big for that motor
Tue Jun 14, 2011 8:46 pm
depends on the boat.
if you have a 1648 or smaller the 9x7 is what you want. if your boat is larger you probably want to drop to a 9x5
Wed Jun 15, 2011 7:46 am
Air bubbles in the filter... does the fuel drain right back out of the filter after you stop pumping the bulb or shut off the motor? That would make me lean toward air leak in the line somewhere.
Backfiring & running like a dog makes me think electrical or ignition system (diodes, coils, shorted out wire).
Andy, anything I'm missing?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jun 15, 2011 9:19 am
thats about it.
if he has a primer bulb, just squeeze it when the motor starts cutting up. that will do the same thing as adding an electric fuel pump and eliminate wether or not he has a fuel supply problem (or something else).
Wed Jun 15, 2011 9:29 am
ok i got it running right it opens up but it backfires through the carb now but it will open up and run good wat could the backfireing through the carb be??
Wed Jun 15, 2011 6:09 pm
when does it backfire, and how often?
Wed Jun 15, 2011 6:13 pm
it backfires like when u give it full throttle and it will clear out but if u let out of it nd get back in it thats when it starts poppin back through the carb
Wed Jun 15, 2011 6:19 pm
sounds like a carb problem (lean pop). I'd open up the carb again, remove the jets and make 100% sure that they are perfectly clean.
Also, make sure that when you re-installed the carb that you didnt pinch one of the gaskets where the carb meet the intake, which would cause the same problem.
And finally one very long shot, have you checked to see if you sheared the flywheel key. I doubt that is the case being that you say the motor will "clear out" and run fine.
Wed Jun 15, 2011 6:33 pm
ok i will check and were can i get rebuild kits for the motor or do u know
Wed Jun 15, 2011 6:48 pm
What are you wanting to "rebuild" exactly?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jun 15, 2011 8:45 pm
Users browsing this forum: No registered users and 193 guests
