It is currently Sat Jul 05, 2025 11:06 am
Reply to topic  [ 16 posts ]
 Mod. a 35hp GDSD
Post Mod. a 35hp GDSD
I have a 35hp GDSD on a GD 16X54 boat. The motor is all stock. Just was wondering what I could do to get it to go faster and have some more power? I am running at about 1000rpm's at idle and about 3800 wide open in the water with a top speed of about 28. Looking for a little more top and low end. Also when I am at idle and get on it, the motor will hesitate a bit before it goes. Any help would be great. Thanks
Sat Jul 09, 2011 12:22 pm
Post Re: Mod. a 35hp GDSD
How much do you want to spend? Where are you located? There is alot or a little you can do to give you more alot of it depends on how much you are willing to spend. Hell 28 isn't bad man mods will give you about on average from what I've seen about a 10-15% increase in top end but the bottom end is impressive.
Sat Jul 09, 2011 12:55 pm
gettin ready to do the IM Heads, BPS Cam, BPS Roller Rockers, and push rods to my 35 GDSD
35HP GATOR TAIL GTR W/ MARSHMELLOW EXHASUT AND MINKUNI CARB PUSHIN MY BIG AZZ AND A
16 X 50 ALUMAWELD HULL.
Sat Jul 09, 2011 12:59 pm
Would like to do something every year. Spending about $1,000 a year.
Motor: 2009 35hp. Briggs GoDevil Surface Drive
Boat: 2009 GoDevil 16X60
Mods: None for now
Sat Jul 09, 2011 1:03 pm
Give yourself about 3 or 4 years. You will be set
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Sat Jul 09, 2011 1:06 pm
Is there anything that I can do to fix the hesitation when I first get on the gas?
Mods: None for now
Sat Jul 09, 2011 1:10 pm
Carb and exhaust will help.
Sat Jul 09, 2011 1:12 pm
Clean the carb. Check your plugs.
Sat Jul 09, 2011 1:13 pm
I have 62hrs on it and I change my plugs 2 times a year. I only run gas that is ethanol free. Where I hunt is in WI. Will a mikuni work ok where the temps get in the low 30's? What kind of exhaust would you recommend?
Mods: None for now
Sat Jul 09, 2011 1:20 pm
BPS Crossover or Marshmellow on the exhaust.
Mikuni will work fine in cold weather.
Sat Jul 09, 2011 1:22 pm
Sat Jul 09, 2011 1:27 pm
Sat Jul 09, 2011 1:29 pm
Sat Jul 09, 2011 2:13 pm
Whats the best exhaust? MM, BPS CrossOver, BPS Dual?
Mods: None for now
Sun Jul 10, 2011 8:05 am
Sun Jul 10, 2011 8:07 am
Personal preference, but the Crossover seems to give the most improved performance.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 10, 2011 8:08 am
Users browsing this forum: No registered users and 152 guests
