It is currently Mon Jul 07, 2025 11:37 am
Reply to topic  [ 26 posts ]
 Thinking about hopping up my 36hp PD
Post Thinking about hopping up my 36hp PD
Thinking about hopping up my PD. Not wanting to go too crazy just want about 10 more horses. Need some direction on what to do
Sun Aug 07, 2011 6:15 pm
Post Re: Thinking about hopping up my 36hp PD
Heads, cam, exhaust...My .02
This topic has been just about beat to death. Lots of info here if you use the search feature. FYI anything than can be done to the 35 mb, gt, or gd can be done to the 36.
Sun Aug 07, 2011 6:24 pm
What about jet kits for the carb an exhaust?? Is that a option that I would have
Sun Aug 07, 2011 6:31 pm
Believe there is only one set of jets for the stock carb. You can drill them out if you wish, but not really necessary. There is a few things you can do to the stock carb and intake to cut down on turbulence if you want. You could also upgrade to a mikuni carb. I kinda like the stock gov set up, but will probably switch over to a mikuni sooner or later.
Don't know what you were asking on the exhaust. Marshmellow has a few options, and BPS has at least one, maybe two.
Sun Aug 07, 2011 6:36 pm
Heads and exhaust would b night and day. U got a CDI motor?
18'x54"CC Hanko/ 36PD
Sun Aug 07, 2011 6:50 pm
18x48 Charles Leonard / 36PD
Sun Aug 07, 2011 6:51 pm
No I don't have the CDI motor. How much would changing the heads an exhausht run ??
Sun Aug 07, 2011 7:06 pm
The exhaust run 400-500 depending on what you get. Heads can run anywhere from 150 bucks to 700 or so depending on who does the work and what all you have done. Where are you from?
Sun Aug 07, 2011 7:19 pm
What is the stage one upgrade. What does that consist of an where is the best place to get it
Sun Aug 07, 2011 7:25 pm
Stage 1 consists of different things depending on who does the work. Usually cam, heads, and exhaust, or carb, heads, and exhaust. Where are you located? Are you comfortable doing the work yourself or would you need to take it somewhere to have it worked on?
Sun Aug 07, 2011 7:27 pm
I'm located in Maurice ,La. Defaintly would want to bring it to someone to do the work
Sun Aug 07, 2011 7:37 pm
BoatDr in Harahan does great work and is very knowledgeable. Little bit of a drive, but worth it IMO. I believe one of our new sponsors, Calen, is in Franklin which looks like it might be a lil closer to you. He seems to have a good reputation with the folks on here as well.
Sun Aug 07, 2011 7:40 pm
Heads and Exhaust first....if you have the cash add the Cam. Only do the carb if you like working on your motor ....just my .02
Sun Aug 07, 2011 7:44 pm
Sun Aug 07, 2011 7:45 pm
I have a 36 pd with heads and exhaust if you wanna see what that would do for ya, Im in Carencro.
Im happy with what I gained by the heads and exhaust.
Sun Aug 07, 2011 7:46 pm
Andy hooked me up with a deal on a used Mikuni that could not be refused, so I'll probably put it on at some point, but I'm not in a huge hurry to try it out. :lol:
Sun Aug 07, 2011 7:48 pm
What about the PD place in Louraville u know if they do stuff like that??
Sun Aug 07, 2011 7:49 pm
Contact calen mire and bring your motor there. When you get it back you'll love it. Easy guy to work with and great customer service also warranty
Sun Aug 07, 2011 7:58 pm
How can I get intouch with him.?? Isn't he located in Franklin ??
Sun Aug 07, 2011 8:01 pm
Yes 3375784434
Sun Aug 07, 2011 8:02 pm
x2 to what garret said, calen did my stage 1 and the difference from stock was like night and day....he does good work and backs it up, when you call him he can tell you more than you want to know on the subject and def point you in the direction you want to be.
Sun Aug 07, 2011 8:10 pm
I plan on calling him in the morning. What's the name of his shop??
Sun Aug 07, 2011 8:24 pm
Calen's engine service. I'd call Andy too, just to get a couple different recommendations and prices. 504-737-1203 Good luck, let us know what you decide to do.
Sun Aug 07, 2011 8:30 pm
Thanks for the input will let y'all know what I decide to do
Sun Aug 07, 2011 8:37 pm
Users browsing this forum: Google [Bot] and 140 guests
