It is currently Thu Apr 02, 2026 3:01 am
Reply to topic  [ 6 posts ]
 HELP!!
Post HELP!!
I have a homemade long tail with a 9hp Honda. I can't seem to get the top part of the universal joint (on the engine) to stay tight. It continues to slide up?? If anyone could help or has any ideas it would be much appreciated.
Sat Aug 13, 2011 5:03 pm
Post Re: HELP!!
if th eu joint keeps sliding up just pull the set screw out drill a hole into the shaft and reset your set screw with loctite
17Foot Aquasport 85 Evinrude
20GDLT Looking for a Hull
Sun Aug 14, 2011 1:07 am
Post Re: HELP!!
yea that will work and a oversize key will help. btw if you can get it, the loctite green "638" is the best. its made for slip fit put it on the shaft and set screw.
Sun Aug 14, 2011 6:02 am
Post Re: HELP!!
I use a collar that I got from my local hardware it slides on before the u-joint and stopped my problems. I think it was like 2-3.00.
Sun Aug 14, 2011 11:24 am
Post Re: HELP!!
I use square head bolts (at least grade5) and red loctite. Tighten with a breakover.
Sun Aug 14, 2011 12:29 pm
Post Re: HELP!!
Thanks for the help guys, it's much appreciated problem is solved!
Sun Aug 14, 2011 5:40 pm
