It is currently Tue Mar 31, 2026 6:52 am
[ 6 posts ] |
quackhead16
 HELP!!
I have a homemade long tail with a 9hp Honda. I can't seem to get the top part of the universal joint (on the engine) to stay tight. It continues to slide up?? If anyone could help or has any ideas it would be much appreciated.
| Sat Aug 13, 2011 5:03 pm |
Powerstroke9773
Joined: Tue Apr 05, 2011 8:01 pm Posts: 164 Location: Nixonton, North Carolina
 Re: HELP!!
if th eu joint keeps sliding up just pull the set screw out drill a hole into the shaft and reset your set screw with loctite
_________________ 17Foot Aquasport 85 Evinrude 20GDLT Looking for a Hull
| Sun Aug 14, 2011 1:07 am |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
 Re: HELP!!
yea that will work and a oversize key will help. btw if you can get it, the loctite green "638" is the best. its made for slip fit put it on the shaft and set screw.
| Sun Aug 14, 2011 6:02 am |
scotts98rt
 Re: HELP!!
I use a collar that I got from my local hardware it slides on before the u-joint and stopped my problems. I think it was like 2-3.00.
| Sun Aug 14, 2011 11:24 am |
specgoos1222
Joined: Tue Oct 19, 2010 7:02 pm Posts: 46 Location: Great Bend, KS
 Re: HELP!!
I use square head bolts (at least grade5) and red loctite. Tighten with a breakover.
| Sun Aug 14, 2011 12:29 pm |
quackhead16
 Re: HELP!!
Thanks for the help guys, it's much appreciated problem is solved!
| Sun Aug 14, 2011 5:40 pm |
[ 6 posts ] |
