It is currently Thu Jul 10, 2025 1:34 pm
Reply to topic  [ 11 posts ]
 engine dying help
Post engine dying help
I'm having some engine issues with my 04 prodrive. It'll run perfect for 1/2 mile or so and then just bog down and die while running full throttle. After it starts right back up but it will do this two or three times. After that it runs perfect again until you stop for a while and them sometimes it will do it again and sometimes it runs perfect. The plugs are brand new...anyone have any idea what would cause this?
Tue Aug 16, 2011 11:40 pm
Post Re: engine dying help
Sounds like a fuel issue! almost like its starving for fuel. do you have a inline fuel pump?
Wed Aug 17, 2011 5:32 am
What hp?
Wed Aug 17, 2011 7:39 am
Next time it bogs down squeeze your fuel bulb and it will tell you if its starving for fuel.
Wed Aug 17, 2011 8:07 am
Ck your vent on your fuel tank, and the entire fuel line for an air leak including any quick disconnects that you have.
Wed Aug 17, 2011 8:25 am
It's a 32. I dont have an inline pump or quick disconnects. At the time I didn't try pumping the bulb while it was dying but I did glance at the fuel filter and it was full and the tank was vented. What's the best way to check the rest of the line for air leaks?
Wed Aug 17, 2011 3:07 pm
if you have a primer ball check that its not sucked flat. you could still see fuel in the filter but if the ball is flat it wont allow the fuel to flow out. if you stop the motor the pump will stop tthe vacume that has the ball flat and you will be able to run some more till it sucks the ball flat again. just another thing to look for.
Wed Aug 17, 2011 3:13 pm
If my fuel filter is empty and I get bubbles when im filling it up with the bulb does that mean I have an air leak? once the filter is fully full though I don't get any more bubbles even if I pump the bulb a few more times.
Wed Aug 17, 2011 7:27 pm
i had a similar problem with my engine. it would run good for a while and then i could watch the rpms steady goin down. it took 3 trips back to the shop before they figured out wt was wrong with it. my choke cable wasnt letting the choke go back fully and was choking the engine and robbing it of power. just something to check out.
Thu Aug 18, 2011 12:57 pm
I'm gonna try to check everything out this evening. Can anyone tell me if the air bubbles when I fill the fuel filter are normal or an air leak? I remember reading something about bubbles in the filter being bad but I don't remember the exact circumstances.
Thu Aug 18, 2011 4:04 pm
Bubbles while priming it are normal (always have been for me anyway), if you prime it up & the fuel drains back out, tell tale sign of air leak.
Like was said before, try pumping bulb when it's trying to die. If that keeps it going, you could have a bad fuel pump.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Aug 18, 2011 6:13 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 118 guests
