It is currently Wed Jun 25, 2025 8:22 am
Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3  Next
 CDI's any leaking crank case gaskets yet?
Post Re: CDI's any leaking crank case gaskets yet?
Mon Jan 09, 2012 9:23 am
my 2010 started leaking at 80 hours.
MoMarsh Fatboy/2 Honda
Mon Jan 09, 2012 9:39 am
My 2011 just started at 39hrs.
1854 Brotha Breaux chased by 36 PD!
Mon Jan 09, 2012 10:50 am
Mon Jan 09, 2012 11:01 am
I have 30 hrs and it is leaking. Almost looks like I have a leak from the filter too. Everything is tight
1754 Xtreme 35 GTR Stage 1
Mon Jan 07, 2013 1:31 pm
Mine leaked at 18hrs on that second bolt from top rt. mine and my buddies was loose same screw. The one that holds the exhaust bracket on
IT IS WHAT IT IS!
YOU BRING YOUR HOUSE DOG HUNTING?.....
Mon Jan 07, 2013 1:53 pm
My 23 leaks slightly right der too at 200 hours.
Mon Jan 07, 2013 1:54 pm
I tightened it up per specs and havnt seen a drop since.
IT IS WHAT IT IS!
Mon Jan 07, 2013 2:04 pm
Mine started leaking at 30 hours
35 gtr pushing a beer can
Mon Jan 07, 2013 4:51 pm
Bookmarked! Great info on this thread.
100 hrs until leak but I had a Hoyt stg 1 from day 1. How bad is too bad to for a new gasket? It's just a slight leak so far.
Mon Jan 07, 2013 5:20 pm
I gave up mud motors
Mon Jan 07, 2013 5:28 pm
Mon Jan 07, 2013 5:46 pm
203 hrs and no leaks!
Mon Jan 07, 2013 7:52 pm
Homemade gasket and light RTV on each side. No worries! Just don't block oil flow ports!
Mon Jan 07, 2013 8:58 pm
Tue Jan 08, 2013 9:37 am
Mine leaks, never had any problem though, I just keep an eye on the oil level. I've had the gasket changed 3 or 4 times, but it's out of warranty now, so it'll just have to leak lol. As CB said, I should probably check the case bolts though.
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Tue Jan 08, 2013 10:29 am
My motor and the big motors Cody build don't have a case gasket and seem to be holding up pretty well
Tue Jan 08, 2013 10:48 am
Rj, was yours using a gasket when the cover cracked?
Tue Jan 08, 2013 11:00 am
Tue Jan 08, 2013 12:11 pm
Tue Jan 08, 2013 12:13 pm
Tue Jan 08, 2013 12:14 pm
Tue Jan 08, 2013 12:18 pm
Gotcha
Tue Jan 08, 2013 12:21 pm
Post the link if u go find it. :lol: I don't feel like using the slow ass browser on my phone. :lol:
Tue Jan 08, 2013 12:25 pm
Red loctite, but you have to get rid of all oil residue first and let it dry before getting any on it. Kinda hard to do. I think I saw a line from loctite that was a little more resistant to oils also, you may look into that. The normal shit at the autoparts store only works well if its really clean.
Tue Jan 08, 2013 12:30 pm
I've seen loctite in a tape form kinda like Teflon plumbing tape I wonder if that would be more resistant to oil
Tue Jan 08, 2013 12:36 pm
Tue Jan 08, 2013 12:38 pm
yes yamabond is what he used on my motor, didnt machine the block just the internals. he squared the case and the block and machined the internals for end play. still use the orings but no gasket.
Tue Jan 08, 2013 12:43 pm
Tue Jan 08, 2013 12:47 pm
Tue Jan 08, 2013 1:10 pm
Tue Jan 08, 2013 1:12 pm
Tue Jan 08, 2013 1:20 pm
Tue Jan 08, 2013 1:22 pm
I tightened two bolts this am before I went fishing. Will have to go see what it looks like.
Tue Jan 08, 2013 1:36 pm
Tue Jan 08, 2013 1:40 pm
Tue Jan 08, 2013 1:46 pm
Tue Jan 08, 2013 2:23 pm
Tue Jan 08, 2013 2:24 pm
Yeah that's kinda what I figured money talks lol. It sounds like a pretty solid way of improving that weak spot on these motors.
Tue Jan 08, 2013 2:30 pm
I got studs on mine and both side are vented mine usually last around 130 or so hrs
17x48 extreme stage 2 GTR
Users browsing this forum: Majestic-12 [Bot] and 124 guests
