It is currently Fri Jul 18, 2025 12:56 pm
Reply to topic  [ 22 posts ]
 Mikuni Carb for 27hp Kohler
Post Mikuni Carb for 27hp Kohler
Can anyone tell me the Mikuni carb size mod number and or part number to fit a 27hp vertical shaft Kohler. A friend of mine has a mikuni that came off a motorcycle figured i see if i could put it on. Thanks.
Matt
Thu Mar 04, 2010 3:55 pm
Post Re: Mikuni Carb for 27hp Kohler
I think they are using a 39mm but I could be wrong. What size is the one your buddy has. If it under a 40mm I bet you could make it work.
BUCK OFAMA
Thu Mar 04, 2010 4:25 pm
We are installing 33mm on the kohlers and 23hp Vanguards that we mod.
Thu Mar 04, 2010 6:59 pm
Don't really know, is there anything special one has to do to install a new carb on a vertical shaft kohler.
Matt
Thu Mar 04, 2010 7:52 pm
What is the series and model number or part number for mikuni carbs is used.
Thu Mar 04, 2010 7:55 pm
BUCK OFAMA
Thu Mar 04, 2010 8:17 pm
Yepper.
Thu Mar 04, 2010 8:56 pm
it's an awesome lil' setup and it brings dem engine's to life!
Fri Mar 05, 2010 8:15 am
What about a 27hp Horizontal shaft Kohler? Can you put a Mikuni on it? Would a kohler 2 barrel work on it?
Sun Mar 14, 2010 9:51 pm
Mon Mar 29, 2010 7:13 am
We have put Mikunis and 35hp Briggs carbs on the 25 and 27 Kohlers. Must change out the intake to do it.
Mon Mar 29, 2010 8:43 am
Mon Mar 29, 2010 10:29 am
Drake1 sells them. www.extremevtwins.com
They also make a 2 barrel carb and intake you can pick up for the horizontal kohler. http://www.mid-atlanticperformance.com/
The mikuni is a much better carb and the setup from EVT will be better. The setup with the double barrel will give you more performance than stock and should be considerably less expensive. I've talked to the guys at both of these places. Both very helpful. Give them both a call, and see which one can meet your needs.
Mon Mar 29, 2010 11:07 am
Anyone have a model number on the mikuni for the 27HP Kohler? I have a stock engine and am looking to get the most bang for my buck in mods. I have been told to get an exhaust and filter, but to see real results look into a new carb and head work. Where can I go to research this, other than here obviously?
Thu Jan 12, 2012 9:42 pm
Post Re: Re: Mikuni Carb for 27hp Kohler
1850 & 36pd
Thu Jan 12, 2012 10:00 pm
Mikuni. It is a 33mm tm flat side with accelerator pump.
Fri Jan 13, 2012 10:45 pm
The Mikuni number is TM33-8012.
Mon Jan 16, 2012 11:45 pm
Any tangible number as to how much of an impact this carb makes on a 27 Kohler? What kind of additional speed or power are we talking?
Mon Jan 16, 2012 11:47 pm
Anyone know if I can use the stock intake with this carb? I have heard people mention different intakes, is there a "best" one?
Mon Jan 23, 2012 5:39 pm
You use the stock intake for the 30hp motor and an adapter.
Mon Jan 23, 2012 5:41 pm
Anyone figure out what you have to do as far as bolting the carb up?
New Intake? If so where do you get it?
Adapter Plate? If so where do you get it?
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sat Jun 30, 2012 11:57 am
I responded to your pm. Forgot, you do need the 30hp intake. I think I still have one, I'll look when I get home.
The adapter plate, got mine from mike. Im pretty sure the briggs is the same bolt pattern though. Maybe if you could get your hands on one for the 23 or 35 and see how it lines up... may also try al.
Sat Jun 30, 2012 12:37 pm
Users browsing this forum: No registered users and 127 guests
