It is currently Sat Jul 12, 2025 9:26 pm
Reply to topic  [ 21 posts ]
 electric fuel pump
Post electric fuel pump
I have 35GTR CDI, I want to move the tank to the front of the boat (approximately 18 ft of hose). Am I going to need to add a fuel pump or will the motor pull it?
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Mon Jan 16, 2012 3:26 am
It will pull it !! But a elec. Fuel pump won't hurt anything!!
17x48 extreme stage 2 GTR
Mon Jan 16, 2012 6:32 am
Post Re: electric fuel pump
After installing the electric fuel pump , is fuel pump bulb
still required?
Mon Jan 16, 2012 5:38 pm
Fuel pump bulb is always required.
You shouldn't need an e-pump to pull that far, run 1/4" fuel lines. People have had a hard time pulling through a 3/8 for some reason that far. Make sure you get rid of your quick connects though, straight connect everything.
Put yer face in the myrtles.
Mon Jan 16, 2012 6:23 pm
I'm putting my boat together now.
Is it better to have the bulb up front with the tank? Or is it just as good back by the motor?
I would think with an empty fuel line and the bulb by the motor it may be hard to suck fuel to back of the boat with the bulb, and air.
Mon Jan 16, 2012 8:21 pm
back by the motor! those things are strong
Mon Jan 16, 2012 8:27 pm
Mon Jan 16, 2012 8:35 pm
Wed Jan 18, 2012 6:57 am
Are you saying direct fuel line from tank to motor, with no primer bulb?
How to prime when fuel line is empty?
What about when you run fuel out of motor then reconnect? No need to prime?
Will Briggs n Stratton vanguard suck if no primer is used?
Thanks for comments. Very helpfull
Wed Jan 18, 2012 11:43 am
Wed Jan 18, 2012 8:07 pm
Thanks for the comments! I currently run a 36 Pro-Drive. An electric fuel pump was added after a fuel issue. Been running it 2 seasons now with no issues. However, this is my current fuel set up:
Starting at the Tank---fuel line----primer bulb----fuel line---in-line filter-- fuel line---electric fuel pump---fuel line----filter---fuel line----carb.
I have always worried about all of these connections. Can someone give me some solid advice on what is actuall needed?
Thanks!
Thu Jan 19, 2012 7:43 pm
All you need is one filter and either 1/4 or 5/16 line, that's it.
Thu Jan 19, 2012 7:45 pm
I run 5/16 hose, about 20 ft and have regular inline fuel filter that comes with briggs (small clear filter) ran it for a long time without primer bulb and worked good, but added primer bulb because at times was hard to start because fuel would bleed back out of filter, now if I see filter is empty, pump the bulb and it fires right up
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Thu Jan 19, 2012 7:58 pm
What type of quick connect do you guys prefer on the fuel tank?
Fri Jan 20, 2012 3:01 pm
Don't use quick connects!
Fri Jan 20, 2012 3:02 pm
Hmmm. Ok
A little inconvenient but way more convenient than paddling a boat for a few miles.
Fri Jan 20, 2012 3:14 pm
They are notorius for leaking and they can cause some major headaches on these low pressure fuel systems.
Fri Jan 20, 2012 3:16 pm
Sun Jan 22, 2012 6:41 am
We always add them even to the stock motors just find they do better when you put them in gear they don't die out as easy
Sun Jan 22, 2012 8:08 am
MMT Moderator
I have a quick disconnect on the tank. No electric pump and a standard primer bulb. I have never had an issue fuel. My tank is forward. Primer bulbs can leak, as well as the disconnects. Fuel can break down cheap hose & connections but if done right you should never have an issue.
If you never want to worry about it do without the disconnects & run your line directly to your tank. Most people run into issues when replacing parts & failing to cut the hose back an inch or so. Some I have seen reusing the metal straps that secure the hose to the fuel tank fitting etc. Most of the issues posted are from air leaking because of a faulty part, hole etc.
GTB 1860 w/ 2019 GTR40XD-HO
Sun Jan 22, 2012 9:35 am
I would have a primer bulb on hand just in case your pump goes out. You know its gonna happen 10 miles from the ramp or help. I dont use quick connects and do have the bulb which is laying on the floor where I could pump it with my foot if my pump ever went out.
18x48 Charles Leonard / 36PD
Sun Jan 22, 2012 10:47 am
Users browsing this forum: No registered users and 122 guests
