It is currently Sat Jul 12, 2025 11:01 am
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2
 Prodrive manual reverse not working HELP!
Post Re: Prodrive manual reverse not working HELP!
What year is it? That should just be access to the grease zerk if it's a newer style. No water can get in the lower unit through there. You can put a pipe plug in it, and you can get one at home depot, but it ain't gonna hurt anything to run without it either.
Fri Feb 03, 2012 8:54 pm
How do I change the Lu oil on these things? Is I t very difficult
2072 Gatortail extreme with dual 35s GTRs
What year is it? Owners manual is posted on the PD website.
Fri Feb 03, 2012 8:56 pm
2008. It makes sense now that you guys are saying that. It's on the outer housing above the tension knob, I just wanted to make sure before I ran it
18x48 Charles Leonard / 36PD
Fri Feb 03, 2012 8:58 pm
access to the grease zert is typically on the other side of the frame.
Fri Feb 03, 2012 9:00 pm
I'm going to do that. Just wanted to make sure I do everything right before I run her. First time running a surface drive. Been running a long tail and I can't wait to run the prodrive
So you don't think it's a 2008? Older?
Fri Feb 03, 2012 9:02 pm
Looked on te website about the Lu oil, it's just the one bolt right guys?
Fri Feb 03, 2012 9:10 pm
Look on the right side of the frame where the sadle sits on the transom. What does the serial number stamped in the frame tell you. First 2 numbers will be the year.
Fri Feb 03, 2012 9:11 pm
Fri Feb 03, 2012 9:13 pm
Thanks I'm not by my motor now but I'll check when I get home
Got it! I think I'm set as far as everything goes now
Fri Feb 03, 2012 9:14 pm
Page 14 shows top plug and page 18 shows bottom plug.
Fri Feb 03, 2012 9:17 pm
Fri Feb 03, 2012 9:19 pm
Agreed cb5331. He has got it going on! If it weren't for this for I would be up sh!t creek without a mudmotor! Lol
Fri Feb 03, 2012 9:22 pm
Fri Feb 03, 2012 9:24 pm
Yall cut that chit out. :lol: There aint room enough for more than one of us to have that swollen head on this site. Terry got that wrapped up. :lol:
Fri Feb 03, 2012 9:25 pm
I knew that would make you blush.... :lol:
Fri Feb 03, 2012 9:27 pm
Grab the end and you can hold it in place while you ratchet if your tension block isn't working
Wed Mar 07, 2012 12:23 am
Users browsing this forum: No registered users and 99 guests
