It is currently Sun Jul 13, 2025 10:11 am
Reply to topic  [ 24 posts ]
 Gtr breather nut comming loose
Post Gtr breather nut comming loose
Ok so Ive got new rig and everytime I run it the damn big plastic nut that holds the breather cover on backs off!! Whats the quick fix. When it gets loose it starts rattling and it's driving me nuts. I have cranked the shit out of it and it still vibrates loose! 35gtr. I dont want to be looking for my cover on the side of the road!!
MUD,BLOOD,FEATHERS. 18/46 gtb with a 35gtr
Tue Feb 21, 2012 10:58 pm
Post Re: Gtr breather nut comming loose
Drill a hole through both sides of the cover and zip tie them together would be an easy solution.
Tue Feb 21, 2012 11:02 pm
I'm thinkin about drilling a hole through the nut and cover where it overlaps and putting and pin or somthing in that rig
Tue Feb 21, 2012 11:08 pm
uhhm, a lock washer?
Tue Feb 21, 2012 11:14 pm
No place to put a lock washer. The nut doesn't bottom out on anything. It the big plastic nut with a nut inserted into it that holds the plastic over on.
Tue Feb 21, 2012 11:19 pm
blue loctite
I gave up mud motors
Tue Feb 21, 2012 11:20 pm
Use some LocTite on it.
I see you're in LC, you should head over here to Port Neches Saturday & see what that motor can do.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Feb 21, 2012 11:22 pm
Bungee cord over the top lol
16x44 Hanko Skiff
35GTR
Tue Feb 21, 2012 11:26 pm
Look at the SETX mud run 2012 forum.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Feb 21, 2012 11:30 pm
Use some duck tape. Cause if you can't duck it..... :lol: :lol:
23gtr crossover Mikuni
Wed Feb 22, 2012 3:57 am
Mine does the same thing. I have to bow up on it,
I mean really twist that SOB, then it wont come loose.
Uncle J 17x54
GTR 35
Wed Feb 22, 2012 8:00 am
Wed Feb 22, 2012 8:08 am
I am the expert on this. Have replaced 3. I screwed the top to the base with 2 self tapping metal screws.
Wed Feb 22, 2012 8:10 am
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Wed Feb 22, 2012 8:16 am
Put yer face in the myrtles.
Wed Feb 22, 2012 5:17 pm
1854 pd with 36fpr
Wed Feb 22, 2012 7:27 pm
Put blue locktite today with channel locks. Guess we will see!
Wed Feb 22, 2012 10:25 pm
I trailer 800 miles each way. Duct tape all the way. 4800 miles and 40 something total running hours on two different motors this year.
Wed Feb 22, 2012 10:40 pm
After loosing the first one on my Pro Drive I over tightened the next one. Then the stud broke and I lost the bracket, filter and cover. Now I have a 6 in. piece of duct tape taped over the nut and it can't turn. Working great so far, cheap and quick too.
Thu Feb 23, 2012 7:33 am
jamb nut
Thu Feb 23, 2012 6:37 pm
what about teflon tape on the threads??
Thu Feb 23, 2012 6:42 pm
So far blue loctite is doing the job. Ran it about 3 hours this morning with no probs
Fri Feb 24, 2012 4:54 pm
Wow, First off if you tighten it to tight it will snap the bolt and you will loose everything but the main backing plate like mentioned above. The simplest thing is tighten it up moderately. Then drill a 1/8 hole through the nut into the cover and install a 3/16 wood screw. If the cover still rattles take a small amount of grease and coat the edges of the metal backing plate and Chase the inside of outer lip of the black plastic cover with a small amount of clear silicone. Install and let cure. Done deal!
Sun Feb 26, 2012 6:01 pm
Users browsing this forum: Google [Bot] and 95 guests
