It is currently Sat Jul 12, 2025 11:51 pm
Reply to topic  [ 13 posts ]
 Even the almighty IM heads valves leak
Post Even the almighty IM heads valves leak
Less than 100 hours on these heads, and the intake valves on both heads leak.
:shock:
Wed Feb 29, 2012 5:35 pm
Post Re: Even the almighty IM heads valves leak
Did you try running any cleaners thru the motor before you took them off?
I've had 2 motors come thru here this month to get ready for fishing season that upon an initial inspection failed a leak down test. But after running a cleaner thru the motor (and getting out all the carbon deposits from running cheap gas) they were fine.
Wed Feb 29, 2012 5:41 pm
18x48 Charles Leonard / 36PD
Wed Feb 29, 2012 5:44 pm
First I started with a decarbonizer (foaming degreaser) called Power Foam from Amsoil. Then ran about a gallon of gas mixed with a shock treatment of Yamaha Ring Free. I also told my customers to run their next 2-3 tanks with some Ring Free just to be on the safe side, but my leak down numbers went from 65% blow by to just under 20% on both motors.
Wed Feb 29, 2012 5:49 pm
No I didn't
I always run a 93 octane with marine Stabil.
Wed Feb 29, 2012 5:52 pm
Wed Feb 29, 2012 6:05 pm
Wed Feb 29, 2012 6:13 pm
Wed Feb 29, 2012 6:16 pm
My stock ones looked just like that. I laped them and put it back together. It runs fine now but I didn't get a chance to put it in the water yet
Thu Mar 01, 2012 12:32 am
Thu Mar 01, 2012 1:06 am
Oh well they are gonna get a valve job and have everything checked out.
Thu Mar 01, 2012 8:50 am
Kind of explains why it was not running like it used too in the mid range huh?
Thu Mar 01, 2012 9:16 am
That and why I had to step up my pilot jet one size larger to get it to come off of idle decently.
Thu Mar 01, 2012 10:56 am
Users browsing this forum: Google [Bot] and 92 guests
