It is currently Sun Jul 13, 2025 12:24 pm
Reply to topic  [ 19 posts ]
 What kind of speed will I get with mods on a 36PD 17 x 54
Post What kind of speed will I get with mods on a 36PD 17 x 54
I have a 2011 36PD 17 x 54 with center console. I haven't gone over 27 mph and the last bit of throttle doesn't help increase speed (that's with no load). I would love to run 32 with a load and I'm willing to spend some money but I would like to stay away from changing the internals.I have just ordered a new QT muffler and plan on getting a set of Iron Mountain Heads . What kind of speed increase will that get me ?? Should I get a carb instead of heads ? If I did all three what kind of increase will I see. I thirst for this information and I haven't been able to get this specific info from prior post. Thanks in advance .http://www.flickr.com/photos/75061757@N ... otostream/
Sat Apr 07, 2012 7:28 pm
Post Re: What kind of speed will I get with mods on a 36PD 17 x 5
You won't see 32 loaded with anything short of a hand gernade of a motor with full internals.
32 empty is pushing it without internals
Sat Apr 07, 2012 7:39 pm
So what can I expect with Iron Mountain heads and a QT muffler?
Sat Apr 07, 2012 7:53 pm
I have the same boat, actually just pulled the console out. I shaved my heads, minor porting and stainless valves. I have a little more compression over what iron mountain heads will give you. I have a marshmellow muffler also....
Basically the same as what you will have and i get 30mph in deep water touching the revlimiter. 4350! i can still get 25mph with 4 grown men gone frogging in deepwater. My normal hunting load i would get about 26-27mph average in deep water.
The heads make a good bit of difference i power due to the factory valves leaking so bad!!
i was running 28 today in the ICY with my wife an 12yr old girl and icechest turing 4150-4200.
also,,,before mods my speeds were about the same as yours.
Prodrives are a little slower due to drive angle is steeper then the others, and the gear ratio allows you to turn a bigger prop which is a little slower then smaller prop with more pitch.
Sat Apr 07, 2012 8:15 pm
T, who did the work on your heads?
35 GTR - 1754 Extreme
Sat Apr 07, 2012 8:21 pm
Thank you, that is the info I was looking for. Keep um coming .
Sat Apr 07, 2012 9:22 pm
Define "load"
Sat Apr 07, 2012 11:16 pm
I would define load as 2 adults and a child , dog , decoys , guns and gear ,so about 750 lbs not including gas.
Sun Apr 08, 2012 1:49 am
heads, exhaust, and carb are a real nice combo. I have this combo on a 16-44 tiller handle and lookin at 31 and bumping 32 with me and the dog. 29 with 3 folks and a cooler. This is the way I would go, even if I had it to do over again.
HOTSAUCE170 wrote:
Sun Apr 08, 2012 5:58 am
If you gonna go for it and our capable of it, add in a cam with the heads and exhaust. Heck if I was you I'd do the carb to if you trying to get some speeds
Sun Apr 08, 2012 9:32 am
Do you want load carrying speed or just run by your self speed, motor can be set up all kinds of ways
Sun Apr 08, 2012 11:42 am
Sounds like he said he wants to run around 32 with a load consisting of 750lbs.
Sun Apr 08, 2012 3:52 pm
ive got the same setup with setx heads, marshmellow exhaust, mikuni carb and high rev coils. im gettin 28 loaded down and jumps on plane quick, but 32 ain't gonna happen. hittin 30-31 empty. give cody at setx a call he will fix u up.
pd36 fpr 1754 cc rig
Sun Apr 08, 2012 9:26 pm
I would love to run 32 with a load but I would settle for touching 30 every now and then. I was running 22mph with 850lbs extra last duck season and it was too damn slow. There is such a big difference in 8mph, enough to shell out big bucks to get it. I guess that puts me in good company. Getting better response from the throttle and faster acceleration will make it all worth it....along with the speed. I have decided to get the Q muffler, single carb and have the heads worked. Thanks to everyone. I will post with the details.
Sun Apr 08, 2012 11:14 pm
I can tell you the load you plan on runnig is pretty much what i run, 2 adults, 1 kid, 1 big as lab and all hunting shit and i would get bout 25mph with that load in deep water. Never clocked it in shallow...i assume it would pick up 1-2 in shallow.
The heads make a huge difference with the load! You will not gain much speed empty with just heads and exhaust. Maybe 1mph, but the load carrying wont drop off as much plus you will notice a big difference in torque...
as for the exhaust, i defenatly recomend somethign different then stock cause i broke my marshmellow and put the factory back on after the head work and could tell it was sluggish....
Mon Apr 09, 2012 4:54 am
@CJB,,,Wasnt sure if the PM went through.....so i answered here to..
I did my heads myself. Had a local machine shop shave them, and i polished them up and installed the stainless valves lapped them, and shimmed them! Defenatly needed on these engines as i could see daylight between the fatory vavles and seats....
I am runnig about 185psi compression over fatory 130=140...
Mon Apr 09, 2012 4:56 am
Turbo drives old 1754 pd with a stage I 32 ran 32-33 mph.
Mon Apr 09, 2012 9:10 pm
i touch 30mph with heads and exhuast....
so i would think you need at least a cam or carb to cross 30mph..
Tue Apr 10, 2012 6:19 am
Thanks everyone!!! ya'll gave me everything I need to make my decission.
Wed Apr 11, 2012 4:41 am
Users browsing this forum: Majestic-12 [Bot] and 131 guests
