It is currently Wed Jul 16, 2025 4:53 pm
Reply to topic  [ 14 posts ]
 Mud buddy mini questions
Post Mud buddy mini questions
kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Thu Apr 12, 2012 9:15 am
Post Re: Mud buddy mini questions
are you speaking of the LA special? or the Mini HD Lite? they are two different frames, and the Mini HD lite does not come in a 35hp option. the LA special is either 35 or 23 hp, and is not 100lbs lighter than the standard. Difference is in the shorter, slightly smaller belt housing and standard 32'' outdrive.
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Thu Apr 12, 2012 9:26 am
There is no such model as a mini 35. As GSU said, the LA special is not any lighter and it and the sport are the only 2 models available with a 35 hp motor.
And you wont get 28 out of a 27hp. 24-26 with a light load, yes.
Thu Apr 12, 2012 9:38 am
On the MB website it is still labeled as " New Mini 35" which is the "Louisiana special, other is mini hd lite.I run a 24 hp mini hd Lite 2 men light boat 24 mph. Hunting loads 19-22 mph on a 1542 beat up boat. So to get consistant 28 mph you would need to run a 35 hp.
Thu Apr 12, 2012 9:48 am
Profile YIM
Ok yea I went on the web site and the LA special is called the mini 35 on there but, I was told that they are alot lighter but I guess the guy that told me that didn't know what he was talking about, the thing is I bought a 1548 wieldbuilt and was worried about a 35 being too heavy, some say it will be ok if I put gas tank a battery up front, I'm just trying to go for speed, I live on the mobile river delta, not a whole lot of mud but alot of shallow water so I'm not really going to be putting I'm whatever motor I buy to the test. Just wanting everyone's opinion on what setup will work the best for me
Thu Apr 12, 2012 10:23 am
talk to Duckhunter251 on here, he has a modded 27hp mini HD lite he runs on at Gator trax 1544HD, but he used to run it bone stock on a 1548 G3.
Thu Apr 12, 2012 10:42 am
Have you looked at the new mud buddy models ?
http://www.mudbuddy.com/Sport%20V.html
GatorHide - MB
Thu Apr 12, 2012 6:06 pm
i run a 27 mini with a b p s exhaust and get 24mph deep water empty on a 1748 weldbilt .100 ga.
Fri Apr 13, 2012 8:10 am
Sun Apr 15, 2012 6:28 am
and the 23 la special is a double barrel bugger to change or even tighten the belt. you cant get to the upper 2 bolts. but is a good tuff motor, I had mine cammed up and and I think that it was money well spent. really woke mine up. took gov out and put a 5100 rev limiter in, and can bump it with a light load
Mon Apr 16, 2012 6:36 pm
Mon Apr 16, 2012 6:58 pm
Use a distributer wrench to tighten the bolts behind the clutch.
Swamprat, you keep running those high rpm's with stock piston rods, & tightening a belt will be the least of your problems.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Apr 16, 2012 9:02 pm
Post Re: Re: Mud buddy mini questions
Mon Apr 16, 2012 9:53 pm
Yea, I know I cant do that, but had to experiment though, keeping it around 4100 but does get up and go a lot faster than ever,
Sun Apr 22, 2012 5:32 am
Users browsing this forum: No registered users and 96 guests
