It is currently Sat Jul 19, 2025 1:19 am
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 35hp problem
Post 35hp problem
I was running today around 4100-4150 rpms and the engine made a pop noise but didn't lose any power. I stopped to see and in neutral it seemed like it had a different kind of vibration. Any ideas?
16x44 Hanko Skiff
35GTR
Sat Jun 09, 2012 6:47 pm
Post 35hp problem
Something broke
Sat Jun 09, 2012 6:56 pm
Post 35hp problem
I need a little bit more than that lol
16x44 Hanko Skiff
35GTR
Sat Jun 09, 2012 7:02 pm
Post Re: 35hp problem
Well according to Robin, if it would be a GoDevil you could rule out the clutch and the transmission. ;)
Sat Jun 09, 2012 7:05 pm
Post 35hp problem
I don't think it was a clutch or transmission. Nothing's slipped
16x44 Hanko Skiff
35GTR
Sat Jun 09, 2012 7:30 pm
Post 35hp problem
Sat Jun 09, 2012 7:44 pm
Post 35hp problem
So back to what could be the problem..
16x44 Hanko Skiff
35GTR
Sat Jun 09, 2012 7:58 pm
Check ur valve train
Sat Jun 09, 2012 8:08 pm
^^^ I was thinking push rods also
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jun 09, 2012 8:47 pm
Post 35hp problem
You would lose power if you threw a pushrod though. Right?
Sat Jun 09, 2012 9:10 pm
1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Sat Jun 09, 2012 9:13 pm
^^^FAIL!!!^^^ Talkin push rods, not connecting rods :roll:
Yeah, Owen, it would run like shit if he threw a push rod. I missed where he said he didn't lose power, was focused on the vibration.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jun 09, 2012 9:17 pm
Could it have been a backfire and you just noticed more vibration because you were paying closer attention to it?
Sat Jun 09, 2012 9:19 pm
Sat Jun 09, 2012 9:20 pm
Sat Jun 09, 2012 9:21 pm
Sat Jun 09, 2012 9:27 pm
Is the motor stock?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Plugs may be in the beginning stage of fouling, pull them and check em. Last time mine popped i had to limp on one cylinder to a hunting hole, come to find out i blew a head gasket. Not your problem cause you would have noticed that.
Sat Jun 09, 2012 11:12 pm
Sat Jun 09, 2012 11:14 pm
You mean helpful like suggesting push rods without any power loss? Or maybe a blown head gasket that obviously isn't the problem either?
I'll keep that in mind.
Sat Jun 09, 2012 11:30 pm
Post 35hp problem
Just carb and exhaust
16x44 Hanko Skiff
35GTR
Sun Jun 10, 2012 2:09 am
Does it idle smooth still? If the idle is rough now, check your intake gasket. It could have ripped and now causing an air leak.
Sun Jun 10, 2012 4:40 am
Might be the baffled in your muffler came loose better check fast them fuckirs will be on top your piston in no time
Sun Jun 10, 2012 7:00 am
Do you have a rev box on it? Could've just been a hiccup in the box, causing a backfire like was mentioned earlier.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jun 10, 2012 7:50 am
Post 35hp problem
No rev limiter. And it does idle smooth. I think im gonna pull the valve covers off and take a look at the rocker arms
16x44 Hanko Skiff
35GTR
Sun Jun 10, 2012 9:34 am
Post 35hp problem
I have one roller rocker loose on each side...is that normal?
16x44 Hanko Skiff
35GTR
Sun Jun 10, 2012 9:48 am
It depends where the pistons are at. Do you know how to set your valves?
Sun Jun 10, 2012 9:49 am
Yes they will be loose when that particular valve is in its seat.
Sun Jun 10, 2012 9:52 am
Post 35hp problem
No I don't know how to set them..
16x44 Hanko Skiff
35GTR
Sun Jun 10, 2012 9:54 am
No better time to learn! Take your time, make sure you get it right.
http://www.youtube.com/watch?v=hGkn0jR9RJM
Sun Jun 10, 2012 10:00 am
Another
http://mudmotortalk.com/mmt_v2/viewtopi ... sh#p228779
1850 & 36pd
Sun Jun 10, 2012 11:24 am
Post 35hp problem
Think I found my problem
16x44 Hanko Skiff
35GTR
Wed Jun 13, 2012 1:44 pm
yup
If you took those three long bolt couplings out and left them out, would it hurt anything?
Wed Jun 13, 2012 1:46 pm
Post 35hp problem
How does that happen? Lol. Should I stress about finding the rod that broke off. Could this possibly be the reason I saw sparks as well?
16x44 Hanko Skiff
35GTR
Wed Jun 13, 2012 1:48 pm
Wed Jun 13, 2012 1:50 pm
Wed Jun 13, 2012 1:52 pm
Post 35hp problem
That metal screen was takin off when I had work done to the engine. Could this have possibly been the reason I saw the sparks out of the side?
16x44 Hanko Skiff
35GTR
Wed Jun 13, 2012 1:53 pm
Wed Jun 13, 2012 1:55 pm
Post 35hp problem
Yeah and it sparked for a little while then made a noise like it threw something around in there then it never sparked again. I have the fan cover with my oil cooler on it I just don't have that other little cover inside the fan cover
16x44 Hanko Skiff
35GTR
Wed Jun 13, 2012 1:58 pm
Thu Jun 14, 2012 6:04 am
Users browsing this forum: Majestic-12 [Bot] and 71 guests
