jakecologne
Joined: Thu Jun 10, 2010 2:57 pm Posts: 933 Location: Des Allemands
 35hp problem
I was running today around 4100-4150 rpms and the engine made a pop noise but didn't lose any power. I stopped to see and in neutral it seemed like it had a different kind of vibration. Any ideas?
_________________ 16x44 Hanko Skiff 35GTR
Sat Jun 09, 2012 6:47 pm |
chaseh
Joined: Thu Apr 15, 2010 1:50 pm Posts: 1230 Location: Waco, Texas
 35hp problem
Something broke
Sat Jun 09, 2012 6:56 pm |
jakecologne
 35hp problem
I need a little bit more than that lol
Sat Jun 09, 2012 7:02 pm |
elebouef102
 Re: 35hp problem
Well according to Robin, if it would be a GoDevil you could rule out the clutch and the transmission.
Sat Jun 09, 2012 7:05 pm |
jakecologne
 35hp problem
I don't think it was a clutch or transmission. Nothing's slipped
Sat Jun 09, 2012 7:30 pm |
OwenDickeson
 35hp problem
Sat Jun 09, 2012 7:44 pm |
jakecologne
 35hp problem
So back to what could be the problem..
Sat Jun 09, 2012 7:58 pm |
richard nagon
 Re: 35hp problem
Check ur valve train
_________________ JUST ANOTHER FARMER ON WELFARE
Sat Jun 09, 2012 8:08 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: 35hp problem
^^^ I was thinking push rods also
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sat Jun 09, 2012 8:47 pm |
OwenDickeson
 35hp problem
You would lose power if you threw a pushrod though. Right?
Sat Jun 09, 2012 9:10 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: 35hp problem
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Sat Jun 09, 2012 9:13 pm |
Team Camo
 Re: 35hp problem
^^^FAIL!!!^^^ Talkin push rods, not connecting rods Yeah, Owen, it would run like shit if he threw a push rod. I missed where he said he didn't lose power, was focused on the vibration.
Sat Jun 09, 2012 9:17 pm |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
 Re: 35hp problem
Could it have been a backfire and you just noticed more vibration because you were paying closer attention to it?
Sat Jun 09, 2012 9:19 pm |
PaleoHuntr
 Re: 35hp problem
Sat Jun 09, 2012 9:20 pm |
Woodiebuster
 Re: 35hp problem
Sat Jun 09, 2012 9:21 pm |
PaleoHuntr
 Re: 35hp problem
Sat Jun 09, 2012 9:27 pm |
Team Camo
 Re: 35hp problem
Is the motor stock?
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: 35hp problem
Plugs may be in the beginning stage of fouling, pull them and check em. Last time mine popped i had to limp on one cylinder to a hunting hole, come to find out i blew a head gasket. Not your problem cause you would have noticed that.
Sat Jun 09, 2012 11:12 pm |
take'emgator
 Re: 35hp problem
Sat Jun 09, 2012 11:14 pm |
PaleoHuntr
 Re: 35hp problem
You mean helpful like suggesting push rods without any power loss? Or maybe a blown head gasket that obviously isn't the problem either?
I'll keep that in mind.
Sat Jun 09, 2012 11:30 pm |
jakecologne
 35hp problem
Just carb and exhaust
Sun Jun 10, 2012 2:09 am |
Will
 Re: 35hp problem
Does it idle smooth still? If the idle is rough now, check your intake gasket. It could have ripped and now causing an air leak.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Sun Jun 10, 2012 4:40 am |
bubba777
 Re: 35hp problem
Might be the baffled in your muffler came loose better check fast them fuckirs will be on top your piston in no time
Sun Jun 10, 2012 7:00 am |
Team Camo
 Re: 35hp problem
Do you have a rev box on it? Could've just been a hiccup in the box, causing a backfire like was mentioned earlier.
Sun Jun 10, 2012 7:50 am |
jakecologne
 35hp problem
No rev limiter. And it does idle smooth. I think im gonna pull the valve covers off and take a look at the rocker arms
Sun Jun 10, 2012 9:34 am |
jakecologne
 35hp problem
I have one roller rocker loose on each side...is that normal?
Sun Jun 10, 2012 9:48 am |
cb5331
 Re: 35hp problem
It depends where the pistons are at. Do you know how to set your valves?
Sun Jun 10, 2012 9:49 am |
Will
 Re: 35hp problem
Yes they will be loose when that particular valve is in its seat.
Sun Jun 10, 2012 9:52 am |
jakecologne
 35hp problem
No I don't know how to set them..
Sun Jun 10, 2012 9:54 am |
cb5331
 Re: 35hp problem
No better time to learn! Take your time, make sure you get it right. http://www.youtube.com/watch?v=hGkn0jR9RJM
Sun Jun 10, 2012 10:00 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Re: 35hp problem
_________________ 1850 & 36pd
Sun Jun 10, 2012 11:24 am |
jakecologne
 35hp problem
Think I found my problem
Wed Jun 13, 2012 1:44 pm |
Will
 Re: 35hp problem
yup
If you took those three long bolt couplings out and left them out, would it hurt anything?
Wed Jun 13, 2012 1:46 pm |
jakecologne
 35hp problem
How does that happen? Lol. Should I stress about finding the rod that broke off. Could this possibly be the reason I saw sparks as well?
Wed Jun 13, 2012 1:48 pm |
BoatDR
 Re: 35hp problem
Wed Jun 13, 2012 1:50 pm |
BoatDR
 Re: 35hp problem
Wed Jun 13, 2012 1:52 pm |
jakecologne
 35hp problem
That metal screen was takin off when I had work done to the engine. Could this have possibly been the reason I saw the sparks out of the side?
Wed Jun 13, 2012 1:53 pm |
BoatDR
 Re: 35hp problem
Wed Jun 13, 2012 1:55 pm |
jakecologne
 35hp problem
Yeah and it sparked for a little while then made a noise like it threw something around in there then it never sparked again. I have the fan cover with my oil cooler on it I just don't have that other little cover inside the fan cover
Wed Jun 13, 2012 1:58 pm |
deadbird8
 Re: 35hp problem
Thu Jun 14, 2012 6:04 am |
