It is currently Sat Jul 12, 2025 1:52 am
Reply to topic  [ 17 posts ]
 Looking to getting a new Motor
Post Looking to getting a new Motor
Hi everyone!
I'm looking into getting a motor for my jon boat and I believe the boat is a 1436 or 1536 not really sure as it is at home at my parents house right now and im living in another city for the summer, What size motor do you guys reccommed i buy to get what I need out of the boat. I will be using it mostly for trapping and might take it fishing once in awhile. I will be mostly using it on rivers and small lakes.
Oh and when you measure your boat for the width is it the bottom that you measure or the width of the boat when you sitting in it
Thanks
Twig
Wed Jul 04, 2012 3:13 pm
Post Re: Looking to getting a new Motor
Ya measure the bottom.You what a LT or SD? Most any motor will work i'd stay in the 10- 16 HP range.
Welcome to MMT
Wed Jul 04, 2012 4:15 pm
I guess it wouldn't matter LT or SD and measure the bottom that helps
Wed Jul 04, 2012 4:21 pm
So it come down to how much ya want to spend.Lots of good motors out there.
Wed Jul 04, 2012 4:24 pm
I'm looking into staying low in price going to college and all. I would like to stay in the 1000 or lower range but we will see
Wed Jul 04, 2012 4:36 pm
You'll have to go used to get close to that price.Try and test run it before ya buy.Good luck
Fri Jul 06, 2012 6:53 am
yeah I know Im not lookin to get anything new, I just want to get places I have never been able to go.
Fri Jul 06, 2012 6:32 pm
1000 bucks, you are looking for an older used longtail, probably 16hp or less. Down here, you will see them pretty regularly. Up in your neck of the woods, I would imagine even the older one's hold their value a little better. That budget may be hard to work with.
What kind of terrain do you run? Why do you think you need a mudmotor?
Fri Jul 06, 2012 6:36 pm
I will be using it for trapping so marshs and shallow rivers and with rocks mostly, I would like to stay under 1000 but if i have to go over that would be fine. I'm mostly looking for something that would be realiable and fun to drive around. I like that you can lift the motor up if you have to go over something, can't do that with an outboard!
Fri Jul 06, 2012 6:56 pm
What about one of those super cheap thai longtail kits and a motor from harbor freight? Could probably build one of those things close to your price range. The shafts are ridiculously long and they come with aluminum props, but long as you can get a ss prop and take good care of it, I would think it would last a little while... Dunno, just throwing it out there.
Fri Jul 06, 2012 6:59 pm
Yeah I was thinking about that but when I look up harbor freight motors they don't seem to carry any motors bigger than 6.5 hp... Maybe I'm not looking at the right place but pretty sure I am.
Fri Jul 06, 2012 7:11 pm
I thought they carried a 13 at one point, but don't really know. Anyway the 6.5 is only a hundred bucks and you can buy an extended warranty that is basically a no questions asked exchange policy for a couple years. It wouldn't be fast, but it would fit your budget.
If you are handy, you may be able to pick up a used lawnmower engine off craigslist for cheap and rebuild it. Northern has a pretty big selection of engines too, but you aren't hardly gonna beat the 100 dollar engine.
*disclaimer :lol: I have never used one of those thai kits and would probably never personally buy one, and usually discourage someone else from buying one, but i was just throwing it out as an option for you. I am in no way trying to convince you to buy one or really even saying it's a good idea, just that it's an option that would fit your budget.
Fri Jul 06, 2012 7:19 pm
Harbor Freight does make a 13hp and i think a 15hp there all predator motors.
Fri Jul 06, 2012 7:23 pm
Fri Jul 06, 2012 7:24 pm
I know they used to i had one.Maybe not
Fri Jul 06, 2012 7:27 pm
Yeah I get what your saying I think Im better off spending a litlle more and getting something that will last and I know it will work. I had the same problem not being able to see them either on their website
Fri Jul 06, 2012 7:29 pm
I started with a 20 lt on a 1436. 20 and 16 block weigh the same, so if a twenty is available, go for it.
Sun Jul 08, 2012 9:55 pm
Users browsing this forum: Yahoo [Bot] and 99 guests
