It is currently Thu Jul 17, 2025 4:45 pm
Reply to topic  [ 12 posts ]
 HELP!!!!!
Post HELP!!!!!
Recently, I put a thinner head gasket, stiffer valve springs, advanced timing 8 degrees, removed governer, pipe, and put a K&N air filter on. And now I'm having trouble getting it to idle, I can get it to run at a fast idle but not a slow one. I'm kinda stumped dont know if it's a carb issue or something else.
Sat Aug 04, 2012 4:17 pm
Post HELP!!!!!
How does it run WFO?
Sat Aug 04, 2012 4:21 pm
Post Re: HELP!!!!!
It runs awesome wide open?
Sat Aug 04, 2012 4:25 pm
Post Re: HELP!!!!!
It runs really rough and kinda sputters when I try to idle it down, so it makes me think it's a carb issue.
Sat Aug 04, 2012 4:27 pm
Post HELP!!!!!
If you're positive the timing key is installed properly, it's more than likely your carb.
Intake leaks can cause it to idle like shit also.
Sat Aug 04, 2012 4:33 pm
Post Re: HELP!!!!!
What motor?
Sat Aug 04, 2012 4:52 pm
Post Re: HELP!!!!!
Honda GX 160
Sat Aug 04, 2012 10:17 pm
Post Re: HELP!!!!!
who needs idle, wide open all day long. but seriously, sounds like intake leak possibly. spray around all intake and carb gaskets with some wd40 while shes up and runnin. an easy check
Sun Aug 05, 2012 8:41 am
Post Re: HELP!!!!!
Yup, it was an intake leak, apparently one of the gaskets was tore a little bit and I didn't notice it putting it back together. So I cut a new one out of a pop box and that fixed it. Thanks for everyone's help!!!!! :D
Sun Aug 05, 2012 8:30 pm
Post Re: HELP!!!!!
Okay, I still need a little more help. Having trouble figuring out how to set up the throttle linkage w/o the governer arm. Any thoughts and lots of pix would be great! Either gonna use a twist throttle or a clutch lever off a dirt bike for the throttle when done or I'm open for other suggestions. Thanks!
Sun Aug 05, 2012 8:54 pm
Post Re: HELP!!!!!
Anyone had any problems with a fly wheel self distructing with the governer removed?
Wed Aug 08, 2012 7:34 pm
Post Re: HELP!!!!!
I had a dog for a pet when I was a kid.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Wed Aug 08, 2012 7:40 pm
Users browsing this forum: Majestic-12 [Bot] and 129 guests
