It is currently Fri Jul 18, 2025 3:20 am
Reply to topic  [ 13 posts ]
 copperhead fuel hookup?
Post copperhead fuel hookup?
Hey fellas i just got a new 12 hp with remote fuel and was wondering can i run a line from the fuel filter straight to the tank or do i need a primer bubble still also?..i was gonna just crimp my line on the filter and run straight to to tank but dont know if that will work properly..thanks in advance
Sat Sep 15, 2012 5:34 pm
Post Re: copperhead fuel hookup?
Can't go wrong with a bulb
What if the fuel pump fails?
B. MacDonald
Sat Sep 15, 2012 6:11 pm
Good point..im no mud motor guru as this is my first.. thanks for the info...tryin to get it goin..havin my transom cut to 16" and should be finished tommorrow and ready to run...ive only read good reveiws and heard of great customer service from copperhead so thats what i went with... i have a 16/42 weldbilt its goin on..thanks again
Sat Sep 15, 2012 8:08 pm
Lol
Advice is free
B. MacDonald
Sun Sep 16, 2012 4:46 am
Good im broke now lol
Sun Sep 16, 2012 8:50 am
I got a 12 copperhead.. tank on top .. it'll go about 6 to 7 miles on that .. its on a 16/48 ... 18 mph all day .. trim perfect 20 mph
1648 polar Crap ducks unlimited 14 hp. Copperhead
Mon Sep 17, 2012 7:14 am
I had remote fuel put on before they sent it to me...didnt want the small tank but glad to hear such good speeds..ill run it first time today or tommorrow
Mon Sep 17, 2012 8:04 am
You'll be very surprised at the power... Post a review when u can ..
Mon Sep 17, 2012 2:44 pm
Well it rained all day so soon as it stops ill test it out..Northeast AL
Mon Sep 17, 2012 8:46 pm
Yes, you want the primer bulb, but you will only want to use it once when you first connect it to the gas tank. Do not keep pumping it like an outboard trying to get the primer bulb hard or you will end up with gas coming out of the carbs. I initially made the mistake of using some heavy duty fuel line for a 115 outboard built-in fuel tank that was too large for the connection and did not seal properly which ends up starving the engine for gas. If you just use a regular Mercury (or other oem line) and pull off the connector on one end, it works fine.
Although it is doable, I personally think you are pushing the limit with a 12 on a 1642. That would probably be a perfect boat for the 18. Hope it works well for you though.
Tue Sep 18, 2012 1:18 am
Ill have an 18 eventually but for now this will do...i usaully hunt alone and dont carry huge loads
Tue Sep 18, 2012 6:37 am
16/42 weldbilt with 2 guys 2 batteries a gun box and 6 gallon fuel ran 17 steady and hit 18 a couple times...needs a lil fine tuning more and i think itll hit 20..ran through some bad thick stuff and never checked up...awesome motors and very well built.... it surprised the crap outta me
Wed Sep 19, 2012 8:15 pm
This motors are more fun than an oiled up drunk chic ... !
Thu Sep 20, 2012 7:51 pm
Users browsing this forum: No registered users and 83 guests
