It is currently Thu Jul 17, 2025 9:59 pm
Reply to topic  [ 15 posts ]
 cam?
Post cam?
my question is if a cam worth putting on.
35hp single carb, heads, duel exhaust on 16x50 tims flat running 29-30mph
Thu Sep 13, 2012 8:40 am
Post Re: cam?
how well are you running carrying a hunting load?
Thu Sep 13, 2012 8:56 am
Post Re: cam?
with three guys two dogs and hunting equipment 26-28
Thu Sep 13, 2012 9:38 am
Post Re: cam?
what you running a 40 merc?
17x 54 with a 35GTR with Calens stage 1
Thu Sep 13, 2012 9:41 am
Post Re: cam?
Haha no man and I'm not lying either, the boat is light and when I put weight in the boat it doesn't really change the speed but everyone tells me the next step for an upgrade is a cam so I just wanted to know if its worth it
Thu Sep 13, 2012 9:46 am
Post Re: cam?
YES
Thu Sep 13, 2012 9:51 am
Post Re: cam?
would you know what gains I would see
Thu Sep 13, 2012 10:01 am
Post Re: cam?
You should run 50+ with ease
Thu Sep 13, 2012 10:04 am
Post Re: cam?
Thu Sep 13, 2012 10:09 am
Post Re: cam?
Thu Sep 13, 2012 10:13 am
Post Re: cam?
A performance cam isn't really going to effect your motor longevity. If your speed doesn't decrease significantly with a load, chances are you won't see a huge change from the cam. If your undecided wait till your case gasket leaks and you have to tear down your motor to go ahead and install one. It's only a matter of time...
Post Re: cam?
Thu Sep 13, 2012 10:21 am
Post Re: cam?
Blah blah blah. Put the cam in you'll be glad you did.
Thu Sep 13, 2012 11:24 am
Post Re: cam?
How many RPMs are you turning to run those speeds?
If you are able to get to max RPM making those speeds, the cam may not make a difference in speed unless you change prop pitch. It should however make it plane faster...
Sun Sep 16, 2012 9:24 am
Post Re: cam?
i turn up right 4400 rpms
Sun Sep 16, 2012 7:23 pm
Users browsing this forum: Majestic-12 [Bot] and 131 guests
