It is currently Thu Jul 17, 2025 10:28 pm
Reply to topic  [ 11 posts ]
 Prodrive Question - Is This Right?
Post Prodrive Question - Is This Right?
Is this normal/correct?
The two round bars coming up from the frame...one is higher than the other. The tall one is rubbing against the engine block when I turn. I looked back at some photos from when I first got the motor. The rods were the same as they are now...one taller than the other.
Sun Sep 23, 2012 9:54 am
Post Re: Prodrive Question - Is This Right?
mine are like that but it's never rubbed on the engine block
pd36 fpr 1754 cc rig
Sun Sep 23, 2012 10:04 am
It rubs the block when the tower bushings are out.
Sun Sep 23, 2012 10:11 am
No it rubs from after some under water impacts and the bar slams against the trim roller and bends. Cut it off to the same height as the other one.
Sun Sep 23, 2012 11:07 am
Or just take a cheater pipe and bend it back
Sun Sep 23, 2012 11:15 am
mine are like that too, but don't rub anything.
MoMarsh Fatboy/2 Honda
Sun Sep 23, 2012 11:34 am
Yea but if you just take the 2 minutes to cut it off and smooth out the edges, you don't have to fuck with it ever again.
Sun Sep 23, 2012 4:35 pm
1748 prodrive 36 fpr w/ some bolt ons...
Sun Sep 23, 2012 8:00 pm
Good luck with the cheeter pipe. Damn near tore motor off boat trying to bend it after smoking a stump WFO.
Cut it off just below bolt and bevel with a file. Takes 2 minutes.
Mon Sep 24, 2012 2:52 pm
You can bend it back with a piece of pipe, it is just a PITA. Bent mine in the marsh and had to bend it back to drive home. Get a buudy to stand on the cavitation plate and get after it. When I got back to the camp I cut it off
Mon Sep 24, 2012 3:09 pm
What purpose do these rods serve?
I talked to Peck this afternoon. He said loosen the set screw on the side and just turn the rod. So, I did it. But, it became trial and error because once rotated, I couldn't lift the foot enough to access the set screw to re-tighten. Found a happy medium to where it was clearing the sump when turning and able to access the set screw. He said it was made of stainless spring steel...so, yeah...pretty tough to bend. I did clobber something (submerged stump?) pretty good Saturday in Sardis Lake. Probably the culprit.
If this becomes a problem, the saws-all will get some use!
Thanks to everybody for their input.
Mon Sep 24, 2012 4:46 pm
Users browsing this forum: Google [Bot] and 102 guests
