It is currently Fri Jul 18, 2025 10:28 pm
Reply to topic  [ 13 posts ]
 valve lash adjustment cdi 35
Post valve lash adjustment cdi 35
looking to adjust my valve lash cant seem to find anything other than questions about it in the search anyone know who has ever posted a video on this or can help me narrow the search... ive noticed the search function is pretty vague. when you try and get a lil more specific it says no results.
any help would be appreciated.
Gator Trax Hybrid 1654 HuntDeck
Sat Oct 06, 2012 4:35 pm
Post Re: valve lash adjustment cdi 35
Couple different ways to do it. I go to 1/4" past tdc on compression stroke & set both valves at .005, then do same on other cylinder. Do it with engine cold.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 06, 2012 4:44 pm
DO you know what top dead center is, cause if not i would suggest taking it somewhere, setting lash wrong can have some bad consiquences.
Sat Oct 06, 2012 10:55 pm
Dam, all this time I thought tdc meant to da corner.
18'x54"CC Hanko/ 36PD
Tue Oct 09, 2012 9:45 am
Cody's way to set valves is much more easy and less chances of messing anything up in the cylinder or breaking off a piece of wood in there or whatever other horror stories people have.
Tue Oct 09, 2012 9:53 am
i got a video hang on, setting lash
http://www.youtube.com/watch?v=Iko2iztt ... plpp_video
Tue Oct 09, 2012 10:02 am
Tue Oct 09, 2012 10:12 am
oh
Tue Oct 09, 2012 11:46 am
Tue Oct 09, 2012 6:42 pm
Wed Oct 10, 2012 4:54 am
Wed Oct 10, 2012 9:47 am
good advice on the lash setting tiller. the bump on the intake side can be felt by holding the intake side push rod and u can still do it ur way. that bump can also cause a inaccurate compression reading if ur not spinning the engine fast enough. some builders that use a bump in the cam for starting ck the compression by spinning the motor backwards. make sense
Wed Oct 10, 2012 8:36 pm
it made no sense to me either.
Wed Oct 10, 2012 9:06 pm
Users browsing this forum: No registered users and 114 guests
