It is currently Fri Jul 18, 2025 12:41 am
Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
 Almost!!
Post Almost!!
ready to get it on the frame and rock and roll
Fri Oct 12, 2012 8:22 am
Post Re: Almost!!
How many motors have you gone trough lol
17x48 extreme stage 2 GTR
Fri Oct 12, 2012 8:23 am
Post Re: Almost!!
Haha working on my 3rd one. I don't take it easy on them at all take driving it like you stole it to a whole new level
Fri Oct 12, 2012 8:26 am
Post Re: Almost!!
Will this one get trough Sunday lol
Fri Oct 12, 2012 8:29 am
Post Re: Almost!!
Don't jinx me one this One hope this one makes it for a while
Fri Oct 12, 2012 8:42 am
Post Re: Almost!!
Fri Oct 12, 2012 8:46 am
Post Re: Almost!!
Over sized pistons, shaved port polish heads, cam, obsiouslu evt intake and carb with busted as MM exhaust
Fri Oct 12, 2012 8:53 am
Post Re: Almost!!
Should last a couple weeks.
Fri Oct 12, 2012 9:01 am
Post Re: Almost!!
Itll be good for a while
Fri Oct 12, 2012 9:09 am
Post Re: Almost!!
what kind of power and speed??
1754 XSeries Kawi Powered PRODRIVE ...
Mon Oct 15, 2012 5:01 pm
Post Re: Almost!!
I couldn't tell you I ran it yesterday for the first time and it ran real good. Didn't have a gps to see what it was doing
Mon Oct 15, 2012 5:02 pm
Post Re: Almost!!
How much over are the pistons? How much are the heads shaved? What cam?
Mon Oct 15, 2012 7:01 pm
Post Re: Almost!!
.020 over Briggs pistons, .050 heads and a bps cam which I might change out for a cam with some more bottom end to it
Mon Oct 15, 2012 7:13 pm
Post Re: Almost!!
Shoulda said something beatle I would have let you use ma gps yesterday
Mon Oct 15, 2012 7:17 pm
Post Re: Almost!!
I honestly wasn't even worried bout it once I started running I knew it was running good
Mon Oct 15, 2012 7:18 pm
Post Re: Almost!!
What was wrong with it before? What was different about your mods?
Mon Oct 15, 2012 7:20 pm
Post Re: Almost!!
I had gps in ma hand most of the time so I could fine tune the trim to best speeds with all the weight I had lol
Mon Oct 15, 2012 7:24 pm
Post Re: Almost!!
The cam bushing in the block went out and got egg shaped. The difference between this one and the other is heads are port and polished and .020 pistons but the rest is the same
Mon Oct 15, 2012 7:25 pm
Post Re: Almost!!
Mon Oct 15, 2012 7:29 pm
Post Re: Almost!!
I was running 27.7-28.3
Mon Oct 15, 2012 7:31 pm
Post Re: Almost!!
With all them kids you was doing good I honestly didn't expect you to run that fast
Mon Oct 15, 2012 7:37 pm
Post Re: Almost!!
I didn't expect to run like that maself with 4 kids and the other Guy lol
Mon Oct 15, 2012 7:42 pm
Post Re: Almost!!
Mon Oct 15, 2012 7:59 pm
Post Re: Almost!!
No I wasn't able to get it replaced well I actually did see if it was possible to get it done. So I had to get a new block and cam for it. I don't mind the questions I like talkin motor. 7 years at caterpillar dads a outboard mechanic and both grandpas were diesel mechanics so I enjoy engine talk
Mon Oct 15, 2012 8:04 pm
Post Re: Almost!!
I didn't think you could replace any of those bearings or bushings or whatever in the block.
Why did you put the .020 over pistons in? I take it you found a used block?
Mon Oct 15, 2012 8:06 pm
Post Re: Almost!!
No you can't replace them. Sucks that you can't cause i would have 2 blocks getting replaced right now.
Yeah I can across a block that was ready to put together that was .020 over so me I'm wanted to give it a shot figured I wasn't putting flat tops it in and was going with stock pistons it wouldnt be as bad as running flat tops
Mon Oct 15, 2012 8:09 pm
Post Re: Almost!!
The .020 overs don't change anything by enough to worry about. I have them in my motor with heads decked 55 IIRC. Compression is right at 200, runs good. I been real happy with it.
Mon Oct 15, 2012 8:12 pm
Post Re: Almost!!
I didn't think it would change anything much cause you take into place your opening up the cylinder so you dropping a slight bit of compression. I actually was thinking about bumping my heads up to .060 with the little bit of bore but I left it cause with .060 stock rockers start to get close to running out of threads for adjustments and I was shown some rockers that were wore slap out with only 100 hrs on them you probably can guess what make
Mon Oct 15, 2012 8:22 pm
Post Re: Almost!!
Speaking of compression I'm going to see what I'm putting out tomorrow
Mon Oct 15, 2012 8:24 pm
Post Re: Almost!!
Your running stock carb huh CB with heads cam and exhaust right
Mon Oct 15, 2012 8:40 pm
Post Re: Almost!!
Yep.
Mon Oct 15, 2012 8:54 pm
Post Re: Almost!!
Tue Oct 16, 2012 4:36 am
Post Re: Almost!!
Tue Oct 16, 2012 6:58 am
Post Re: Almost!!
If that's what it'll be putting out that'll make me happy
Tue Oct 16, 2012 7:06 am
Post Re: Almost!!
185
Tue Oct 16, 2012 7:08 am
Post Re: Almost!!
Well let's just start takin bets haha
Tue Oct 16, 2012 7:16 am
Post Re: Almost!!
I got 185, shaved .045
Tue Oct 16, 2012 7:25 am
Post Re: Almost!!
Lot lower than y'all thinkin. 175
Tue Oct 16, 2012 11:29 am
Post Re: Almost!!
Tue Oct 16, 2012 11:31 am
Post Re: Almost!!
I was expecting something around there and not closer to 200
Tue Oct 16, 2012 11:36 am
Users browsing this forum: No registered users and 101 guests
