It is currently Thu Jul 10, 2025 1:28 pm
Reply to topic  [ 39 posts ]
 homemade surface... other one got deleted
Post homemade surface... other one got deleted
Building a 13 hp homemade sd, my other thread got deleted. Here it is, any suggestions, opinions. All welcome im new to this so tell me what ya think! Running a 32 tooth on top and 44 on bottom. The prop is a 10x8. And the motor is a 420 predator which says 13 but the other 420 is a 16 hp, dont understand that one!
35 GTR chasin a BBC 1848
Mon Oct 15, 2012 10:11 am
Post Re: homemade surface... other one got deleted
you gonna run dual 13's...that would be pretty cool....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Oct 15, 2012 10:53 am
That would be, but aint gonna happen chief, the frames being built to accept a 35 after huntin season.
Mon Oct 15, 2012 11:13 am
I want to see finshed pics. Thats alot of work and I think its pretty damn cool.
BUCK OFAMA
Thu Oct 18, 2012 9:30 am
Thanks man, i made a little more progress but nobody seemed to be interested on here, ima prolly finish it up this weekend so ill take some more pics and post em
Fri Oct 19, 2012 4:54 pm
Yeah post all ya got id like to see what ya did
I assume you work at a machine shop!!
Fri Oct 19, 2012 6:51 pm
Lookin good
Fri Oct 19, 2012 11:51 pm
Thanks fellas! Got a little bit done today, almost ready to put motor on, just kinda mocked it up to see what she gonna look like. Tell me how shes lookin!
Sat Oct 20, 2012 4:59 pm
And a few more!
Sat Oct 20, 2012 5:00 pm
Good start! You may need to beef up your 2 tabs for your steering, especially if you add a 35. How are you taking the prop thrust? Shoulder on the drive shaft? How are you going to tension the belt? You will learn a lot during the first build...
Mag10
Sat Oct 20, 2012 7:34 pm
Well the two angle irons will have a 1/4" plate on top. Where they mount the holes will be slotted then when tightened there will be a weld to keep it there. In tje bottom of yhe housing there are 2 bearings and 2 thrust busglhings with a seal on yhe backside then the cap keeps it all in there with sealent and a set screw
Sat Oct 20, 2012 8:46 pm
Got it mounted up and only 8mph. Working on that one, waitin on tach and new prop.
Wed Oct 31, 2012 10:23 am
Take apic from side at back of boat. With the drive tube level. Might need a longer belt housing if drive angle is off.might be the reason for 8mph looks good tho.
Wed Oct 31, 2012 10:56 am
Like this? The box is 2 1/8" from the bottom of my boat. The drive tube is square to the box.
Wed Oct 31, 2012 11:29 am
Well it don't look to bad the flatter the angle to bottom the better. How high does water draft on boat. It might be the prop possibly.you want that belt housing as close to water when running as possible without dragging.
Wed Oct 31, 2012 11:48 am
What size boat that on
Wed Oct 31, 2012 11:55 am
1436 When the boat is sitting the box is about 1/4" out the water. But 8mph put the nose of my boat reaching for the sky which puts my box in the water about 1.5"
Wed Oct 31, 2012 11:56 am
That looks like a fun project. Are you a welder?
Wed Oct 31, 2012 12:07 pm
Does it feel like the prop is slipping when you give it full throttle? Kinda goes the same same speed even after you back off to about half.?also how deep are you having to trim down to get a bite.
Wed Oct 31, 2012 12:08 pm
I don't know the exact specifics, but the farther back the housing is the Higher it needs to be because the water will push up after it exits the bottom of the boat. As long as you can plane the boat and the bototm of the housing is out of the water on plane you will be ok. Do not hold this to be 100% truth, but that is how one would think to set it up.
Wed Oct 31, 2012 12:09 pm
Yes I am a welder, in laffayette. Now that you say sumtin , yes bout slippin. I notice a little bit of change but not much from half throttle to full throttle. Maxxis, thanks for the advice I thought the further back the faster it wpuld plane, isnt that why people put jack plates? Thanks for the help guys
Wed Oct 31, 2012 3:11 pm
When my gator trax had wrong transom angle and height it slipped bad just like you ran about. Could be either wrong prop . Drive angle. Or drive length
Wed Oct 31, 2012 9:38 pm
Do you have any pics or dimensions your willing to share of the tail.
This is one of the tidest home builds I've seen photos of.
Being on the other side of the world the only short tail I've seen in the flesh was on a trailer going the other way at 100k and its only the second I know of in the country.
Keep me posted on how it goes.
Cheers
Quote:
Thu Nov 01, 2012 2:14 am
Odass I'm leaning more towards the wrong prop, hopefully. I have the 10x8 and waiting in drive shaft for it. Well see I gotta see how much tweaking I'm gonna have to do with the motor, possible mods? Idk. Everything seems to line up right maybe my drive is to long?
Thu Nov 01, 2012 5:09 am
Get that tach hooked up man see what kinda rpms you got. If oow it hits the governor it's not a motor issue it's a gear ratio or prop not hooking up due to not enough prop or bad angle because of transom height. Good luck buddy
Thu Nov 01, 2012 8:18 am
hey man just found this thread i think u did a great job. i built a homemade one a few months ago so i know what you went through and just wanted to commend u on your hard work
Sun Nov 04, 2012 7:53 pm
Tach,10x8 prop, and flat black. And new throttle. Done!!
Mon Nov 19, 2012 5:00 pm
How fast is it now?
Mon Nov 19, 2012 6:54 pm
No clue didn't have time to drop it in the water. I will thursday. Let y'all know how it goes
Mon Nov 19, 2012 8:09 pm
Had a chance to put it in the water. No speeds because about half way through the test I popped the cord so I couldn't get it back started. I did however manage to get up pretty fast in about 5" of water.
Thu Nov 22, 2012 6:31 pm
Is this your first build?
1850 Uncle J
Delta Performance level 4 GTR
Thu Nov 22, 2012 8:04 pm
Yeh
Thu Nov 22, 2012 8:26 pm
I have the same size boat, 6.5 HP predator, 9x8 prop. I am getting 16 MPH in deep, open water and 18 in shallow water. Will post some pics tomorrow.
Mon Dec 03, 2012 11:37 am
Same for me gents 14x36 riveted jon, 6.5hp harbor freight greyhound, 9x8 hill marine prop. Motor slightly modded getting about 15mph deep water with me and 70lb lab. 1.63:1 gearing. Also, with over a 500lb load it drops to about 10 or 11 mph but will still plane. Good enouph for me :D :mrgreen:
All I can say is build away, I have great respect for you all because I know what these home builds entail just to get a finished product that is usable and halfway reliable. Merry Christmas to all
Sat Dec 22, 2012 9:24 am
1.63:1
Wed Jun 26, 2013 3:26 pm
fowllife08, build looks awesome!! great fab work
Thu Jun 27, 2013 10:30 pm
Thanks I built this last year and ended up selling it to a guy to crawfish with, he added a clutch and still runnin it. He put it on a 18' skiff and said it done what he needed. Im in the middle of trying to decide if I wanna build a 23 right now
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Fri Jun 28, 2013 5:30 am
nice build bro. looks good
18x46 40.
Fri Jun 28, 2013 7:26 am
Fri Jun 28, 2013 9:21 am
Users browsing this forum: No registered users and 133 guests
