It is currently Fri Apr 10, 2026 7:18 am
Reply to topic  [ 10 posts ]
 gas pouring out of mikuni
Post gas pouring out of mikuni
i recently put the 42mm mikuni on my GTR i had to install an alectric fuel pump, the stock fuel pump couldnt keep up. bought it from the local oreilys same size like all the guys on here told me to with. now while the motor is running i steady have gas pouring from the drain on my carb.
17/54 extreme hull stage 2 GTR(Hoyt's mods). 34.2mph @4450rpms
Fri Nov 23, 2012 9:19 pm
Post Re: gas pouring out of mikuni
I had the same problem. I put a fuel pressure regulator from the same aisle right after the pump set to 4 psi and it works great. I also like that if I get in a bind and have to replace it, it doesn't matter what psi the pump is.
Fri Nov 23, 2012 9:30 pm
awesome thanks man, but the pump says 2-3.5 psi on the bottom of the box will that still work?
Fri Nov 23, 2012 9:35 pm
You need to bend your float tab and that'll stop the gas from pouring out, Known in the Mikuni's
Fri Nov 23, 2012 10:40 pm
My pump is also listed as 4psi.
Fri Nov 23, 2012 10:42 pm
speaking of i need to replace my pump, probably gonna go with a fuel pressure regulator this time ROD
Fri Nov 23, 2012 10:43 pm
i dont wanna have to bend anything ill try a fuel pressure regulater out tm
Fri Nov 23, 2012 11:07 pm
Its nothing bad its normal on the mukuni's some do it some don't i had to do mine, it just allows the float to put more pressure on the seat and seal it off and not keep letting fuel pour in the bowl.
Fri Nov 23, 2012 11:09 pm
Sun Nov 25, 2012 7:31 am
correct
Sun Nov 25, 2012 1:44 pm
