It is currently Tue Jun 24, 2025 6:00 am
Reply to topic  [ 39 posts ]
 2012 GTR caliper & gasket help
Post 2012 GTR caliper & gasket help
I was doing my maintenance yesterday on my '12 35GTR and noticed that the pad is rabbing/grinding on the caliper. I have 114 hours on the engine. Is this normal wear for the reverse? Or would this be some type of warranty issue? I never heard of changing it. Any advice would be great.
Also my gasked is leaking on my motor. Its not leaking much but you can notice is from every trip. I have seen a couple of other motors that have this problem. anyone else have this problem? I think the gasket is covered under warrany, and i will bring it in after the season to get replaced
Thu Jan 10, 2013 12:19 pm
Post Re: 2012 GTR caliper & gasket help
Don't know on the caliper, but make sure the case bolts stay snug. Small oil leak is okay, loose bolts are not.
Thu Jan 10, 2013 12:21 pm
you have 0 pads left and your rotor is toast. Yea I think you need to go get it checked
17x48 extreme stage 2 GTR
Thu Jan 10, 2013 12:23 pm
Looks like you need new pads. Those are shot.
Thu Jan 10, 2013 12:24 pm
Call GT and get the caliper issue worked out with them. I can imagine that they would make it right since your motor is still under warranty. I have a leak in the same exact spot. See this thread for more....
viewtopic.php?f=3&t=25495
Thu Jan 10, 2013 12:31 pm
Your reverse must suck running it like that
How do you not know anything is wrong to let it go that far.
Thu Jan 10, 2013 12:34 pm
^^no shit. ^^Must have been noisy as hell with all that metal grinding.
Thu Jan 10, 2013 12:43 pm
You are lucky your cover didn't light up from the heat.
Once fixed you may pick up 300 or more rpm. :)
Thu Jan 10, 2013 12:47 pm
Looks like your pads are not level. I mean the bottom of your pad looks to be making contact whereas the top is not. Put I little wd-40 on the prongs just under the pad. Had a semilar problem and it was the pad not returning to its original position after I used reverse it could not slide back. Looks like a fair amount of corrosion on there. And everybody's crankcase gasket leaks
EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Thu Jan 10, 2013 12:58 pm
is there a after market part # for pads or do you have to buy from gt?
- Mark Twain
Thu Jan 10, 2013 1:05 pm
U can get regular break pads but u gotta make sure they are the same
It would be the best thing to go to Gator Tail
I have 160 hours on mine and they never went out but I just got break pads and changed them
Hunting, fishing, family and friends is all you need to make life good!!!
17x48 with a GTR 35 Stage 2
Thu Jan 10, 2013 1:44 pm
Changed my pads around 140hrs. They wore just like that, have not looked at new set to see how the are wearing yet.
Gator tail
Thu Jan 10, 2013 1:53 pm
Well, being this is my first MM, i dont know all the sounds just yet. About 20 hours ago, i noticed a sound but never could figure it out. Thats when i noticed the caliper. Im going to give hoyt a call and see what they say
Thu Jan 10, 2013 3:07 pm
Just talked to Bubba with GT and he told me to ride it out to the end of the duck season and he is going to hook me up with new gasket and calipers and check the whole thing over! Main reason i went with GT is becuase of the service. Thanks again to all yalls comments.
Thu Jan 10, 2013 3:13 pm
Lol don't burn the fucker up
Thu Jan 10, 2013 3:17 pm
Did Bubba look at the pics good?
Thu Jan 10, 2013 3:18 pm
gasket isnt leaking bad at all but they are still going to replace it. I will check it often until i can get it to him
I just emailed the pics to him. Hopefully he emails me back
Thu Jan 10, 2013 3:19 pm
Thu Jan 10, 2013 3:21 pm
Thu Jan 10, 2013 3:22 pm
greentrout......where u at, i got some spare pads if u close by.
Gator tail
Thu Jan 10, 2013 4:16 pm
Im in thibodaux. I probably wont use it this weekend and bubba told me i can bring it to him in houma and he will take it for me. So i will see if he can take it next week so i can get all of that taken care of. I rather my huntin season end early than to mess up my motor
Thu Jan 10, 2013 5:14 pm
Thu Jan 10, 2013 8:26 pm
Seems like the number of gt post from problems is catching up to the number of mudbuddy problem post.
1648 gd hull flying in front of a stage 3 with fpr
Fri Jan 11, 2013 8:27 pm
At least with GT, the parts are available and we know where to get them. :P
Gator tail
Fri Jan 11, 2013 8:41 pm
Sat Jan 12, 2013 12:21 am
Tool
Sat Jan 12, 2013 12:27 am
Sat Jan 12, 2013 12:44 am
You chastise the guy for not knowing he has a problem, but post all over the place that your chit never breaks while trashing everybody else. Guess I struck a nerve. Think I'll have another drink and look around some more.
And FYI, looks like your inferiority complex is showing itself again, remember there are people out there that can give you the help you need.
Sat Jan 12, 2013 12:54 am
Sat Jan 12, 2013 12:55 am
Once your pad is gone of course the rotor is going to get torn up.. I am curious to hear if GT actually covers this under warranty
1944 skiff with 35 GTR
Sat Jan 12, 2013 5:45 am
Wouldn't expect them to cover reverse pads.....thats something thats gonna wear. Mine wore pretty quick, I will always keep a spare set.
Gator tail
Sun Jan 13, 2013 8:38 pm
Isn't premature pad wear a sign of operator error? Low fluid/pressure, not squeezing the lever hard enough? I thought the pads on those things were supposed to last a long ass time, no?
Sun Jan 13, 2013 8:59 pm
I've got 200+ hours on my original pads with barely ant wear on them.
Sun Jan 13, 2013 11:09 pm
Old pads use to last forever. New ones don't last worth shit
Mon Jan 14, 2013 7:00 am
O and make sure you get that email from bubba notarized
Im new to the MM world so I dont know everything to look for. Never once did i think to check my brake pads. Alot of you know what you are talking about BECUASE you have experienced it yourself or learned from someone elses mistake. I dont get on here every single day like alot of people. Im learning as i go. Only thing i knew how to do was check and change oil frequently and LU grease and trans oil. Now as far as my pads go, i think the pads are sticking close to the rotor and that is whats causing the problem of them wearing fast. If i have to pay for the rotor and pads then fine.
Mon Jan 14, 2013 11:55 am
I do appreciate the in put from some of the people and the ones that do want to help. Im not bashign anyone on here, but i dont know everything, never claimed to know everything.
Mon Jan 14, 2013 11:56 am
Users browsing this forum: No registered users and 104 guests
