It is currently Sat Mar 28, 2026 9:53 am
Reply to topic  [ 12 posts ]
 What does this part do???
Post What does this part do???
There's a shaft that comes out of the rear of the engine bout a inch long by the governor. It has a price that links to your carb on it. It will move about a eigth of a rotation. What's it called and whats its job?
Fri Mar 15, 2013 12:05 pm
Post Re: What does this part do???
If I am understanding you right, that is your governor, its job is to govern the motor. I sure would like to know what you are calling the governor.
Fri Mar 15, 2013 12:18 pm
horizontal are vertical engine?
Fri Mar 15, 2013 12:21 pm
I was thinking the govanor was the the slide with the screw on it.
Fri Mar 15, 2013 12:23 pm
What is on the shaft once it is inside the engine. Just trying to learn thanks
Fri Mar 15, 2013 12:25 pm
Vertical 36pd
Fri Mar 15, 2013 12:28 pm
Yes I understand that I'm curious what's on the other side of the govorner shaft? And does it do anything internally
Fri Mar 15, 2013 12:31 pm
centrifugal counter weights, The governor rod is shaped like a hockey stick on the inside and as the weights spin they get thrown outward lifting a small tappet like shaft and it push against the governor rod. the faster the engine spins the greater the force.
I've recently did some ****** rigging to the governor linkage till some parts get here. The butterfly valve to the govaner is opening and shutting fine. But after I rev it up it's slow to idle down once it does it does fine??
Fri Mar 15, 2013 12:35 pm
Fri Mar 15, 2013 12:46 pm
That's awsome. Preciate that. You wouldn't happen to have a pic or diagram of how the linkage, and springs are supposed to be hooked up from the all thread on the throttle to carb? Anyway thanks again
Fri Mar 15, 2013 12:48 pm
