It is currently Sun Sep 21, 2025 6:33 pm
Reply to topic  [ 13 posts ]
 Big Blade and tiller torque
Post Big Blade and tiller torque
I put on a new MB big blade prop and ran it about 30 min’s. It felt like it had more tiller torque than with the smaller blade. I have always ran the smaller blade prop and just wondered if this was normal. I am going to take it out all day on Sunday a just see if I have to trim it different. Just wanted some thoughts.
1652 w/ MB Mini 35
Thu Oct 15, 2009 12:39 pm
Post Re: Big Blade and tiller torque
I ordered the big blade prop two weeks ago from MB, still no prop :cry: called MB just now, they said they were on backorder :evil: My small prop is in bad shape. Wrench in hand waiting!
Boomer Sooner!
Tue Oct 20, 2009 4:13 pm
I have had mine for about two months just din't have time to put it on.
1652 w/ MB Mini 35
Tue Oct 20, 2009 4:25 pm
did you take it out this last weekend, how did you like it?
Boomer Sooner!
Tue Oct 20, 2009 4:35 pm
Took it out but I think I must of bent my skeg when changing the prop because I still have lots of torque but I think I know how to fix it know and it should work better. I will find out how it does with a load on Tuesday.
1652 w/ MB Mini 35
Tue Oct 20, 2009 4:41 pm
The big blade will have more torque than the smaller props.
Tue Oct 20, 2009 5:57 pm
I have always run the smaller prop this is my first Big blade do you think i should try runing it more before messing with my skeg.
1652 w/ MB Mini 35
Tue Oct 20, 2009 5:59 pm
I dont see how you bent the skeg taking the prop off :?:
Boomer Sooner!
Tue Oct 20, 2009 9:21 pm
I don't know my other prop was really stuck and one of the times I slipped I might have bent the skeg. Just trying to figure out the new torque but dog walker might be right so I am going to try to run it more and move some stuff in my boat before I start trying mess with the skeg.
1652 w/ MB Mini 35
Wed Oct 21, 2009 8:47 am
MMT Moderator
Shift more weight to the left or offset your motor if its easy to do... if not then bend that skeg left a little (to the port) and that should help your torque...
GTB 1860 w/ 2019 GTR40XD-HO
Wed Oct 21, 2009 8:57 am
I moved mine 1 inch to the left and it helped
16 x 48 Alweld - 36 PD FPR PT&T
Thu Oct 22, 2009 11:03 am
Thu Oct 22, 2009 12:49 pm
My motor already sits one inch to portside and it is bolted to the transom.
1652 w/ MB Mini 35
Thu Oct 22, 2009 12:56 pm
cron
