50fps
 Stainless valve for stock Briggs heads ????
Anyone got a source for them, don't want the oversized ones tho. Just an upgrade from the stock ones.
Mon Nov 30, 2009 8:17 pm |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
 Re: Stainless valve for stock Briggs heads ????
X2
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
Tue Dec 01, 2009 7:50 am |
basinhunter
Joined: Tue Jan 13, 2009 6:22 pm Posts: 1642 Location: Morgan City, LA
pm Coondik
_________________ Pro Drive m'fers
Tue Dec 01, 2009 7:59 am |
drake1
EVT has got em.
Tue Dec 01, 2009 8:13 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Tue Dec 01, 2009 12:10 pm |
JD
I found some from manley. They are 30 over . Call wayne " harahan auto and machine shop" jefferson hwy, harahan louisiana. He can install and do a 3 angle valve seat. 30 0ver will allow for a real good valve seal but not push the engine to hard. Don't deck the heads unless they need it ,you see better bottom end and midrange just due to proper seal.
JD
Tue Dec 01, 2009 8:50 pm |
50fps
Heads are already decked .055 with a 5 angle valve job, just want to go with the stainless in order to avoid failure of the stockers.
Tue Dec 01, 2009 9:55 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Tue Dec 01, 2009 10:29 pm |
JD
Wed Dec 02, 2009 7:04 am |
blaze
Joined: Tue Jan 13, 2009 4:55 pm Posts: 340 Location: Outskirts of Chocolate City(Westwego)
Wayne does good work over there. Off the subject a little but he did my motor work on my jeep. Dam good guys over there.
_________________ 18X54 Center Console GTB/GTR35(lil daddy mods) http://community.webshots.com/user/blaze715
Wed Dec 02, 2009 9:04 am |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Wed Dec 02, 2009 5:24 pm |
coondik
thank you Prestonia!
Wed Dec 02, 2009 8:43 pm |
50fps
JMO, but these blocks will not handle more than 200 psi for the long term. If you want more ya gotta go with the Kohlers.
Wed Dec 02, 2009 8:51 pm |
coondik
Wed Dec 02, 2009 9:21 pm |
bussterwyatt
what is wrong with roller rockers ? ive got em on my motor and any motor i got that can reduce friction is a good thing . I think you just increase flow and reduce friction everything is good . maybe you guys can get shaver,donovan, or rodake to make you a billet block and crank for 5 grand do the harley engines run that bad to not install them on a short shaft? just seems way cheaper and twice the hp than doing all the upgrades on a lawnmower engine and having it in the shop constantly
Thu Dec 03, 2009 8:16 am |
JD
When I was looking to replace my cam last year , I called precision cam. That is who welds them up for EVT. He told me that the roller rockers had to much duration to use with a cam that had .300 of lift.
I thought the same way you do about friction. If you are increasing the load on the cams enough to break them are you really making more hp.
The roller may be OK with less lift , my bps cam looks brand new My tac broke right before the last breakdown I guess I have 50 hrs +- on the cam.
JD
Thu Dec 03, 2009 9:10 am |
SP
Back on topic- Gecker has stock stainless valves. I have them in my motor.
Thu Dec 03, 2009 9:43 am |
deadbird8
Thu Dec 03, 2009 11:58 am |
SP
Imagine that.
Thu Dec 03, 2009 8:00 pm |
