It is currently Thu Jun 26, 2025 4:38 pm
Reply to topic  [ 19 posts ]
 Stainless valve for stock Briggs heads ????
Post Stainless valve for stock Briggs heads ????
Anyone got a source for them, don't want the oversized ones tho. Just an upgrade from the stock ones.
Mon Nov 30, 2009 8:17 pm
Post Re: Stainless valve for stock Briggs heads ????
X2
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Dec 01, 2009 7:50 am
pm Coondik
Pro Drive m'fers
Tue Dec 01, 2009 7:59 am
EVT has got em.
Tue Dec 01, 2009 8:13 am
BPS has them for 25 bucks a piece!
http://www.backwaterperformancesystems. ... ge%203.htm
Tue Dec 01, 2009 12:10 pm
I found some from manley. They are 30 over . Call wayne " harahan auto and machine shop" jefferson hwy, harahan louisiana. He can install and do a 3 angle valve seat. 30 0ver will allow for a real good valve seal but not
push the engine to hard. Don't deck the heads unless they need it ,you see better bottom end and midrange just due to proper seal.
JD
Tue Dec 01, 2009 8:50 pm
Heads are already decked .055 with a 5 angle valve job, just want to go with the stainless in order to avoid failure of the stockers.
Tue Dec 01, 2009 9:55 pm
Tue Dec 01, 2009 10:29 pm
Wed Dec 02, 2009 7:04 am
Wayne does good work over there. Off the subject a little but he did my motor work on my jeep. Dam good guys over there.
18X54 Center Console GTB/GTR35(lil daddy mods)
http://community.webshots.com/user/blaze715
Wed Dec 02, 2009 9:04 am
Wed Dec 02, 2009 5:24 pm
thank you Prestonia!
Wed Dec 02, 2009 8:43 pm
JMO, but these blocks will not handle more than 200 psi for the long term. If you want more ya gotta go with the Kohlers.
Wed Dec 02, 2009 8:51 pm
Wed Dec 02, 2009 9:21 pm
what is wrong with roller rockers ? ive got em on my motor and any motor i got that can reduce friction is a good thing . I think you just increase flow and reduce friction everything is good . maybe you guys can get shaver,donovan, or rodake to make you a billet block and crank for 5 grand :lol:
do the harley engines run that bad to not install them on a short shaft? just seems way cheaper and twice the hp than doing all the upgrades on a lawnmower engine and having it in the shop constantly
Thu Dec 03, 2009 8:16 am
When I was looking to replace my cam last year , I called precision cam.
That is who welds them up for EVT. He told me that the roller rockers had to much duration to use with a cam that had .300 of lift.
I thought the same way you do about friction. If you are increasing the load on the cams enough to break them are you really making more hp.
The roller may be OK with less lift , my bps cam looks brand new
My tac broke right before the last breakdown I guess I have 50 hrs +- on the cam.
JD
Thu Dec 03, 2009 9:10 am
Back on topic- Gecker has stock stainless valves. I have them in my motor.
Thu Dec 03, 2009 9:43 am
Thu Dec 03, 2009 11:58 am
Imagine that. :lol: :lol:
Thu Dec 03, 2009 8:00 pm
Users browsing this forum: Google [Bot], W3C [Validator] and 132 guests
