It is currently Fri Jul 04, 2025 7:51 pm
Reply to topic  [ 61 posts ]  Go to page 1, 2  Next
 hairline crack
Post hairline crack
I got some oil creaping out of the gasket around the filter so I was trying to pin point exactly where and I notice what appears to be a hairline crack runing horizontaly up to the oil filter I seem to remember reading on here that someones else did this more than once. I'm aware thats not great and it will probably get worse but until it bust open its not realy a big deal aint it? I got stage two mods and run about 44-4600 rpms depending on conditions yall think its from vibs or heat? Or the fact that my motor has been opened up about ten times in the past 4 months?
Tue Dec 24, 2013 6:47 pm
Post Re: hairline crack
Anytime you have an oil like you should be concerned. It can go from a littles oil leak to locked up motor while running to the blind in the dark.
Tue Dec 24, 2013 6:51 pm
Fricken Briggs.... Sorry to hear that, ak.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Dec 24, 2013 6:54 pm
Thought mine was a crack, too, but upon closer inspection looks more like a casting crease/ridge.
Tue Dec 24, 2013 6:57 pm
Briggs really need to improve on the product but I don't think they expected people to alter them to push the stage 2 power levels.
I think they are missing the boat not developing a another motor for this application.
Tue Dec 24, 2013 7:16 pm
They leak and crack when they're stock too..
Tue Dec 24, 2013 7:18 pm
Tue Dec 24, 2013 7:29 pm
Tue Dec 24, 2013 7:32 pm
If it's the oil filter housing leaking, it's an oring. Just take filter off pull bolt out and change it. 10 min job if that..
Tue Dec 24, 2013 7:57 pm
^^ bingo, they can blow out and you will loose all of your oil very quickly, if this happens at dark hrs you will never see it and it could be to late.
Tue Dec 24, 2013 7:58 pm
Only fix is to buy a new motor though aint it? So might as well run it
Tue Dec 24, 2013 8:01 pm
It doesn't take long and next thing u know u will have a rod hanging outside ur block, ask me how I know :lol:
Tue Dec 24, 2013 8:03 pm
U can buy a short block. U sling a rod u could wipe out ur cam, possibly wreck heads if piston hits. U would mess up $2000 in mods
Tue Dec 24, 2013 8:04 pm
The rod threw from motor locking up from no oil or the gasket leaking oil?
Tue Dec 24, 2013 8:05 pm
Verify it's the crack leaking and not filter housing. The filter housing can be changed if that's leaking. if it is the block u have buy new block.
or it could be the 90 degree fitting leaking and it will look like the filter leaking!!!!!
Tue Dec 24, 2013 8:06 pm
If u run the motor out of oil when crack gets bad which will happen if it's the block and will drain oil in less than 5 seconds the rod is usually first to go.
Tue Dec 24, 2013 8:07 pm
Ima get some pictures tomorrow the oil seems to be leaking from the vertical gasket that connects to the pan by the shaft no sure on the terminology the oil isn't coming from filter or the crack if it is a crack. Does it help to tighten down on the bolts or will I need to pull it apart and change gasket?
Tue Dec 24, 2013 8:11 pm
So ur crankcase is leaking? If its cracked and oil leaking out it, change crankcase cover. It's just gasket and isn't leaking back retorque bolts to 17ft-lbs and check/monitor oil level. When begins leaking bad or have time change gasket.
Tue Dec 24, 2013 8:19 pm
The gasket Im talking about is the red line and I drew the region that its leaking the bolts I circled also seem to have oil resdue almost like its leaking through maybe my oil is getting to hot and very thin? the "crack" would be on the right side of the gasket.
Tue Dec 24, 2013 8:24 pm
The red line is normal follow my post before one up. If the crack runs from there to filter and is leaking oil u need a new block
Tue Dec 24, 2013 8:26 pm
well its not coming out of the crack but thats not to say it wont eventually. I sall on two feathers small engines short blocks are 1200 is that about right or is there a better place if I need one?
Tue Dec 24, 2013 8:29 pm
Dont they have an oil pressure kill switch that kills spark if there is no oil pressure?
Tue Dec 24, 2013 8:30 pm
thats what I was thinking maybe it would happen to fast.
Tue Dec 24, 2013 8:35 pm
Mines been leaking there for a while, bayouboy discovered a crack on my main case cover. I can't shut down right now to fix it, so I'm hoping it will make it to Jan 19.
Gator tail
ya its so tiny hopefully it will be fine i guess all i can do is watch it. my motor only has 80 hrs on it and only 15 with the mods so if it blows I will definetly not be putting stage 2 back on because im sure thats what caused the crack and I will have to replace the block either way so ima run with it. hopefully its casting ridge like dgruidy said I'ma look closer and say a few prayers hah.
How many hours you got on yours with the crack and has it got any worse?
Tue Dec 24, 2013 8:43 pm
Spray it with degreaser to clean it good. Then run it and check it every so often to see if you can pin point it.
Tue Dec 24, 2013 8:45 pm
Flex seal. It will make a screen door into a boat surely it will seal a leaking case gasket
Sent from my iPhone using
Tue Dec 24, 2013 8:54 pm
Tue Dec 24, 2013 8:56 pm
Nature of the beast. Briggs sucks for this application. These motors weren't made to do the things we do with them.
Tue Dec 24, 2013 9:00 pm
why would they. This way we go through them every ten hours.
Tue Dec 24, 2013 9:02 pm
Tue Dec 24, 2013 9:05 pm
Gator tail
Tue Dec 24, 2013 9:22 pm
I tightened those two bolts you referenced above and this stopped my gasket from leaking there.
Tue Dec 24, 2013 9:29 pm
Tue Dec 24, 2013 9:37 pm
Go to napa and buy a liquid dye penetrant testing kit. It's easy to use and you will know for sure if it's a crack or if it's just a casting mark. Generally if it's a crack it will pour oil and not just seep.
Tue Dec 24, 2013 9:39 pm
Tue Dec 24, 2013 9:40 pm
Tue Dec 24, 2013 9:43 pm
they aren't on there already?
Tue Dec 24, 2013 9:51 pm
Even with the low oil sensor, when it gets that low it can cause damage.
Tue Dec 24, 2013 9:53 pm
Users browsing this forum: No registered users and 182 guests
